Home > Maintenance & Modifications > Capping off braided lines
Bluest
If got them famcy Pioneer flexi pipes to the front calipers so I can't clamp them off to remove the calipers. Any other ideas on how to keep the fluid in the system? 2007 110 TDCi Station Wagon XS
Post #1072453 29th Jul 2025 10:14pm
Wedge the pedal down and/or seal the reservoir cap so no air can get in.
Post #1072454 29th Jul 2025 10:17pm
Bluest
I've tried the sealing of the cap method before and it didn't work, not sure why,
How does pressing the pedal down work? Does it need to go to the floor? 2007 110 TDCi Station Wagon XS
Post #1072456 29th Jul 2025 10:49pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I had some spare unions knocking around, I think i used female for the rear pipe to rear caliper and male for the front hose - flared up a short bit of 3/8 brake pipe and bashed the other end closed and folded it over and it sealed ok. Stayed on there for 2 weeks whilst doing work and no drips. 1953 80"
1987 mini city e
2011 90"
Post #1072457 29th Jul 2025 10:54pm
When the pedal is pressed fluid cannot pass from the reservoir to the cylinder.
Another approach would be to disconnect the hard lines from the (inboard end of the) hoses and cap them off promptly.
You're inevitably going to lose some fluid whatever you do but it shouldn't be much.
Post #1072458 29th Jul 2025 10:55pm
Bluest
Yes, I don't mind loosing a bit 9f fluid, but just don't want to drain the system. It happened to me before and bleeding through the ABS was a real pain.
I don't prefer to find a way to seal it off with some unions as suggested. 2007 110 TDCi Station Wagon XS
Post #1072470 30th Jul 2025 8:26am
Bluest
Are the unions m10? 2007 110 TDCi Station Wagon XS
Post #1072472 30th Jul 2025 8:31am
jst
M10 x 1 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1072477 30th Jul 2025 10:22am
Bluest
Thanks, in which case I can get a pack for next to nothing in Halfords. I've got some copper brake line and a flaring tool so should be able to make something useful up 2007 110 TDCi Station Wagon XS
Post #1072500 30th Jul 2025 1:08pm
donmacn
Interesting topic for me as I have the same brake lines and have often wondered what I’d do the next time I needed to disturb the system.
I’d be grateful if you’d post a pic or two of what you come up with - save my ageing brain! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1072534 30th Jul 2025 8:58pm
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
Contrary to popular belief It is safe to clamp braided brake lines as long as you use a rounded clamp ! these brake lines can withstand huge pressures and all you are doing to stop the brake fluid is gently squeezing the line together. this type of brake line is a lot stronger than you think .
Post #1072578 31st Jul 2025 4:15pm
Bluest
My clamps are like this one, could they be used?
https://www.mve-online.com/product_info.ph...anguage=en 2007 110 TDCi Station Wagon XS
Post #1072580 31st Jul 2025 4:23pm
mark1200
I would think they are ok as they dont have a v shaped/sharp edge, just remember you only have to nip them up to stop the brake fluid dripping dont overdo it.
the brake system is not under any pressure so you will be ok.
Post #1072581 31st Jul 2025 4:28pm
Bluest
Here my solution in the end. Female is just a bit of rubber in a female fitting. Male one is a short bit of brake pipe crimped closed. Works a treat.
Post #1074037 25th Aug 2025 2:14pm
