![]() | Home > Puma (Tdci) > Oil pressure switch connector |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
just write (copy/paste) "puma 2.2 oil pressure switch" on your browser and
![]() ............................................................. Earth first. Other planets later |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 406 ![]() ![]() ![]() |
Thanks. Itβs the loom connector I need. Not the actual pressure switch. π. I canβt find the connector easily 2015 90 XS Santorini Black
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
The connector is YPC909180 - available from JLR.
However, this doesn't come with a terminal or seal. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Maybe this one fits: FT76116 Puma 110" SW
Brilliant. Thank you. π. 2015 90 XS Santorini Black |
The connector is from the TE (AMP) Sealed Sensor series.
It's a 1-way Code A female connector, which can be bought from Simtek, here - https://www.simtekuk.co.uk/product.php/1_w...:::5830476 ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Perfect. Thanks so much π 2015 90 XS Santorini Black
Ordered ![]() |
