Home > Td5 > AC fan running when not requested
landy andy
Got an issue where my AC fan is running when my AC isn’t being used (don’t really use the AC).
I know the fan can be used to cool the engine if the ECU thinks the engine is too hot, so gets the AC fan to help, but mine is coming on as soon as I start the engine, even when minus temps. Most of the time I can then briefly run the AC, then when I turn off the AC the fan also turns off, and I think that is it till next time.
Drove a couple of hours Friday and when I got to destination AC fan running. My engine temps never even get to mid position, and all cooling system runs well. Today on way back stopped at fuel station after an hour, and fan running. This time operating the AC, then AC off, doesn’t stop the fan running. Pulling the relay did though.
Any thoughts?
Post #1061148 23rd Feb 2025 4:26pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Take a diagnostics equipment and look for faults in engine ECU. Probably some logged overheat fault. Clean it. This is standard TD5 behavior to switchnon the electric fan after overheat to protect the engine. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1061187 23rd Feb 2025 11:04pm
grafty99
I can confirm as I've just had this on mine after a full rebuild. I must have had the ignition on at some point with the coolant sensor unplugged.
Any fault relating to the cooling system will make the ECU request AC fan until the fault is cleared. Erased all of the faults on mine and no more constant fan Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #1061258 24th Feb 2025 7:56pm
landy andy
Thanks both for your input, but not the case for me. No faults showing on nanocom had checked it before but just checked again, and still clear.
Typically though, no fan running today.
Post #1061311 25th Feb 2025 11:47am
landy andy
Noticed it running again today. Checked nanocom. Not ecu faults. But nanocom shows AC Fan requested. Even though all switches off.
Post #1062048 5th Mar 2025 10:33am
TexasRover
There was a very recent discussion here I recall where a person had the AC fan running without there being a demand and it was concluded that after an overheat event the ECU plays it safe and kicks in the fan. I think was resolved by clearing the codes.
Does not explain the compressor though so maybe not going to be that simple.
Post #1062073 5th Mar 2025 3:28pm
landy andy
Yes. That is correct, but I have no codes, and temps all read ok.
Puzzling
Post #1062096 5th Mar 2025 7:39pm
bankz5152
Your coolant temp switch connected/working correctly?
The AC fan will come on if the ECU thinks theres even a chance of over heat, inc if the coolant switch is broken/ not connected.
Post #1062103 5th Mar 2025 8:33pm
landy andy
Yep temp gauge and temp on nano both all good.
Post #1062115 5th Mar 2025 9:35pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I had this recently and it was a dry joint in the air con control box that sits behind the 2 switches, I stripped the unit and re-soldered the joints and it was sorted.
But even if there isn't a fault showing in the ECU, clear the faults anyway, if it was an overheat it doesn't show a code but needs clearing to stop it.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1062183 6th Mar 2025 1:59pm
landy andy
Interesting read. I’ve cleared the no code, and no change, so possibly the dry joint as you’ve had.
Did you get any pics of it whilst you were fixing it??
How easy is it to get too??
Post #1062253 7th Mar 2025 9:15am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Remove the speaker under the switch panel and you should be able to see it. Reach in and unclip it. Then gently pull on he wiring loom and reach in and unplug it.
Good luck Thumbs Up
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1062303 7th Mar 2025 6:11pm
landy andy
Finally got fed up with fan running nearly permanently. Spent some time trying to track down best price for replacement relay/circuit board/AC Control box. Anywhere that was a lower price, no stock and not available. Finally stumped up £183 for a copy (Britpart) version being far far cheaper than the LR one.
Came really quickly and well packed but is a very cheap looking black box. But on disassembly of it the circuit board is exactly the same as my original LR, same manufacturer and part numbers.
Just plugged it in, and for the first time in ages, no fan running, and AC still works.
Cant see anything wrong with the original but I’m not an electronics type guy.
But fingers crossed
Post #1072065 23rd Jul 2025 2:05pm
