Home > Maintenance & Modifications > 21.6 PROBLEMS DETECTED WITH DRIVER DEMAND
vitsdef
Italy 2000 Defender 90 Td5 SW Alpine White
Hi all, this is my first post, so excuse me if the topic has been discussed but I can’t find anything similar to this.
for some months this thing happened to me, every now and then, not always.
Generally at low revs: either in traffic or in 2nd gear on light dirt, going slowly anyway.
The MIL engine light comes on and the defender no longer accelerates, just idles.
If I turn it off and then on again it restarts and generally for a while the problem does not show up again, then it reappears.
Work carried out to try to eliminate the error in chronological order:
- cleaned the potentiometer and its sensor with contact cleaner
- changed the injector harness and no oil contamination
- sensor changed MAP / IAT
- clean MAF sensor
- changed potentiometer (I believe mine is a 2 track)
The error appeared again while in traffic on Saturday and this is why I am asking you for some help.
Nanocom data:
21.6 PROBLEMS DETECTED WITH THE DRIVER DEMAND (LOGGED)
Track 1 throttle: 0.953v -> 4.718v
Accelerator track 2: 4.353 -> 0.350
Track 3 throttle: 0v -> 10v
Throttle power supply: 5.037v -> 5.037v
I still don’t get how it’s possible that the track 3 gives me values between 0v and 10v.
After the above data I deleted the errors and changed, for curiosity, the setting of the potentiometer on the nanocom from 3 to 2 tracks, and it didn't give any problems for 8km of driving.
What else can I check? I have nanocom, although I’m quite a beginner.
LAND ROVER DEFENDER 90 from 2000 TD5 vin SALLDVB88YA184701
No mapped ECU. 110k km.
Thanks! Very Happy
Post #948604 8th Apr 2022 11:48am
landy andy
I would have thought that a 2000 year Td5 would only be a two track pedal, and not the later 3 track one.
Post #948819 9th Apr 2022 8:51pm
vitsdef
Hi, yes, i made a mistake:
"...the setting of the potentiometer on the nanocom from 3 to 2 tracks..." -> should be "...the setting of the potentiometer on the nanocom from 2 to 3 tracks...".
This weekend the error came up twice again.
Maybe i should re-do the wiring from the pedal to the ECU?
I was looking at the electrical diagrams of the TD5 and need a clarification:
what is header 0291 (K109), it doesnt appear in the connector library, and where is it? Shocked Shocked
Post #949824 19th Apr 2022 10:14am
landy andy
I’ve redone the wiring from ecu to pedal 3 or 4 times now using trailer cable (as it has enough strands inside) and it not that difficult to do.
Post #949882 19th Apr 2022 8:37pm
vitsdef
Thanks, i've redone the wiring and it seems it has cured the problem!! Very Happy Very Happy
Post #950514 25th Apr 2022 6:42pm
Joakim Svensson
Sweden
What pins is it on the ecu?
Post #1071612 17th Jul 2025 6:59am
