Home > Maintenance & Modifications > Upgraded Headlight Harness - Where to Buy?
Beco90
Hi all,
The recent thread on LED headlights https://www.defender2.net/forum/topic96225.html has prompted me to seek out an upgraded headlight relay for my Defender. I don’t really like LEDs so would like to stick with getting the most out of the output of my standard headlights.
In my previous Defender I fitted a loom from the Dutch outfit Land Reiziger. However when searching for them earlier sadly they seem to have closed down.
Can anyone recommend where I can source a good quality upgraded headlight loom? I’m aware of the Red Bison/Boomslang version but would like to avoid that given its poor reputation for quality and the use of only one fuse and a fuse holder with a reputation for melting/failing - I don’t want to run the risk of losing both main and dipped beam. See here for example: https://www.defender2.net/forum/topic45391.html
I don’t have the ability to make my own, so was hoping that another small business might have stepped in to fill the gap in the market. Can anyone recommend a good option/supplier?
Many thanks
Post #1071337 13th Jul 2025 8:07am
I have a Land Reiziger loom on mine, pleased with it, as you say, a shame they aren’t any longer available.
I would make my own if I needed one, but I know that isn’t an option for everyone.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071347 13th Jul 2025 4:51pm
fogbank
Having had the Landrigzier on H7s in wipac crystals and LEDs there’s no comparison, I’d personally never not have LED, the best but sadly not legal were the classic car LEDs in the crystals, the normal h7s were so bad i decided it was worth the risk running the LED bulbs until i could put some sealed units in, i eventually went to Truck Lites to stay legal but they weren't as good as the wipacs with LEDs .
Post #1071352 13th Jul 2025 5:58pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
https://www.paddockspares.com/pm330-boomsl...-loom.html
There will be other sources…
Google defender headlamp loom upgrade.
Post #1071356 13th Jul 2025 6:15pm
Beco90
custom90 wrote:
Contact PaulMC on here, I’m sure he will be able to help you out with that.
Thumbs Up
Many thanks for this - I’ll drop Paul a DM to see if he would make something up for me. Otherwise maybe I’ll have to put a wanted advert up for a Land Reiziger loom and hope someone has one on a shelf after swapping to LED units!
Yes, I wish I had the knowledge and confidence to build my own but it doesn’t seem safe or sensible to teach myself on a fairly critical system haha
Post #1071429 14th Jul 2025 5:44pm
Beco90
Notyalc wrote:
https://www.paddockspares.com/pm330-boomslang-performance-headlight-loom.html
Thanks - that was actually the version I was trying to avoid Shocked but it did lead me to spot that FlatDog are advertising a “heavy duty” version of the Boomslang loom, although it doesn’t explain in exactly what way its heavy duty… possibly waterproof relays. I’ve emailed them to ask whether the heavy duty version is now properly fused. I’ll post any reply I get here for others.
Post #1071430 14th Jul 2025 5:46pm
fogbank
Might also be worth speaking to Dan Padmore who owns pace automotive, he’s been very proactive with wiring fixes.
Post #1071435 14th Jul 2025 7:25pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
It's just some wire and relay holders.
I've, previously, purchased a "boomslang" one new.
If I was ever to need another, I think I'd get one of the £15 eBay ones and extend the wires if I needed to.
Post #1071448 14th Jul 2025 9:46pm
Vitesse
I re wired the lighting circuit completely on my Puma not long out of the factory. Appopriate relays and new loom to fit in with the existing setup. That was 10 years ago and have had zero issues with the lighting electrics. I run crystals (don’t like the LED headlamps ) and are perfectly good enough for me.
But I agree that fitting the aftermarket loom or developing your own solution definitely helps the standard headlights to perform better and in my case I am still running the original switchgear 👍 2015 90 XS Santorini Black
Post #1071557 16th Jul 2025 10:36am
Ceramic plugs can be a better option for halogen (incandescent bulbs) due to heat, but with LED standard is fine. Personally I just used plastic, as whilst the ceramic can be better with heat, it can also be slightly brittle and less resilient, so something to think about. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071559 16th Jul 2025 10:47am
