Home > Technical > 2.2 TDCI engine rattle
Pughey14
I’ve had a 2.2tdci recon engine recently fitted, it makes a rattle noise when cold accelerating in low gears between 1500/2500rpm. It doesn’t make the noise on idle or when engines warm. It’s had the same injectors in from previous engine that ran quite. I’ve took it back to my mechanic who’s said with spending money on trying to diagnose the problem he carn’t risk sending the engine back and them to test it to say nothings wrong.
Can anyone help diagnose who’s had similar problems or know anyone who I could take the engine to get a second opinion in the midlands area.
Post #1071050 8th Jul 2025 10:20pm
Dinnu
I don’t know if anything internal would be audible.
I know my exhaust heat shield rattles a bit, as it broke one of its fixings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1071124 9th Jul 2025 4:38pm
Siwynne
Mine does this. I’ve rebuilt mine with new pistons and rings after honing the bores. All measured within tolerances but obviously slightly bigger now on the bore. Doesn’t do it when warm. I think it’s the pistons rattling in the bores when cold and small.
There are also two or three points that can minutely change the timing on these engines
1 the available turn on each cam sprocket when setting up
2 the sideways movement available in the crank position sensor bracket
I am convinced alterations to these have effected how noisy mine is when cold in the past
I have an 8 mile drive on slow A roads on way to work before motorway and no rattle but a two hundred yard roll downhill to the motorway on the way home and hit the motorway still cold and it rattles if I accelerate hard on the on slip. I just drive sympathetically
Post #1071152 9th Jul 2025 10:18pm
