Home > Td5 > Rocker shaft bolts .... renew every time or reuse ?
alexatnd
Hi
Simple question, when removing the rocker arm ( TD5 10p) , the LR workshop says renew every time. Is that what people are doing ? Or can you reuse them ? torque settings are only 32nm
slowly getting there with my. head replacement. Head fine, no dielsel leaks into oil, no coolant leakages happy bunny from thart point of view but the reconditioned injectors i put in,
clouds of unburnt diesel at startup every morning
missfire that clears up ( was really really bad to start with then got better)
and smell of unburnt diesel when running.
To strt with nanaocom said there was a big imbalance between injectors
Am just removing the reconditioned injectors to send back and. putting in the original ones for now.
Other small annoyance, LR copper washers ... no matter how much i clean the injector with ultra smooth sandpaper cant get copper washer down to the end. Turner engineering ones... just the perfect size . Anyone else seen this ?
A
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1064315 31st Mar 2025 4:08pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Renew mate. I had one snap on me not even at torque spec. Had to have it machined out which was £££.
The new bolts from LRparts.net were £8 for the set Shocked 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #1070917 5th Jul 2025 11:22pm
