![]() | Home > Maintenance & Modifications > Digital Dashboard |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2682 ![]() ![]() ![]() |
Chaps,
Has anyone here done this kind of mod? https://metekstore.com/products/land-rover...5091307581 ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
circlethewagons Member Since: 11 May 2024 Location: Brisbane Posts: 28 ![]() ![]() ![]() |
No offence but, I can't see the point of it. It doesn't seem to give any more information that the analogue setup.
You'd be adding a cheap bit of Chinese tech that's bound to fail more often than the existing dash. If you use something quality like a Haltec dash, that'd be cool because it shows a tone more info than standard. I'm not sure it would be easy to retrofit though. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
I’d have a chat with Gary @ Alive or Pete @ BAS, they will likely know quite a lot about these. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1344 ![]() ![]() ![]() |
I saw something like this for a Disco3/4 when I was looking for phone holder on Aliexpress. Cheap like $200-300.
If you find what you want, probably worth looking at the Chinese websites you might find its the same for a fraction of the cost. If you are going to make your car less reliable you might as well save the cost. But then if it's Plug-and-Pray you could always revert to the factory setup (and hope your odometer does not end up doing funny stuff) |
