![]() | Home > P400e Area (L663) > BECM error codes, should I be worried! |
Metisse Member Since: 03 Jun 2022 Location: Wiltshire Posts: 11 ![]() ![]() |
Hi Johan6504,
Did you resolve these faults? I have just found the last two are now present on my vehicle and I can't clear them. I noticed that the car was reverting to the petrol engine when there was plenty of charge available and EV mode had been selected. Many thanks Peter[/code] 2022 Defender 110 HSE P400e Tasman Blue |
Johan6504 Member Since: 13 Jul 2020 Location: Partille Posts: 15 ![]() ![]() |
Hi
I am still getting these from time to time. Clearing them can be done using gapiid tool, resetting all to factory settings. LR has not been able to explain why I am getting them... |
Many thanks, I'll keep trying and will let you know any results. 2022 Defender 110 HSE P400e Tasman Blue
DutchdefenderX Member Since: 25 Dec 2024 Location: Amsterdam Posts: 9 ![]() ![]() |
Very Lickely your HV Heater died. Happens on many PHEV (also non landrover) is a warranty issue. You can notice this when your car doesnt start in ev immidiatly.
Hi DutchdefenderX, thanks for the heads up.
It's not the HV heater as that was replaced a few months ago under warranty and the fault codes were different and specific to the heater. The car runs normally now and has stopped switching back to the engine unless there is no charge left or I make a big demand for power. If there is anything further that comes up from this I'll follow up on this thread and grateful for others input and experiences. Peter 2022 Defender 110 HSE P400e Tasman Blue |
