![]() | Home > General & Technical (L663) > Defender 90 Commercial - Rear Load Space Query |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
It’s tight, but doable. Have you got the bulkhead in or out?
| Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1325
I have the bulkhead in..
I couldn’t get 4 22inch alloy wheels/tyres in. 3 in the back..1 on passenger seat.. kinda crazy 😂 Last edited by Clemmo on 27th Jun 2025 8:21am. Edited 1 time in total |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3529
l've had four wheels in the back of my 90 Commercial you stack three on the left and put one alongside. The top wheel of the stack, move it over to the right and it will keep the fourth wheel from moving.
Put a towel over the top of the fourth wheel to avoid the possibility of marking the headlining. Obviously you can put one on the back, instead of the spare. But l assume you want to carry five wheels in total. This is with the steel wheels and the three in the stack are quite close to the roof. lf your wheels are much wider you won't get three on top of each other. |
| NEDXT Member Since: 27 Jan 2022 Location: Sussex Posts: 40
Bulkhead is still in but it looks doable just . |
If it's too tight I'll use the spare wheel carrier for the 4th and risk driving back without a spare |
Cheers, I'll update the thread with how I get on. |
