![]() | Home > In Car Electronics (L663) > Signing in |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 112 ![]() ![]() |
Yes tick the box to remember you.
![]() If you can’t see it straight away log in then logout then go back to login and it comes up when you are asked for a pin, tick the box BEFORE entering pin ![]() 24MY HSE X-Dynamic 90 Carpathian Grey |
johnlad Member Since: 18 Dec 2023 Location: Blackpool Posts: 103 ![]() ![]() |
I get the same thing most times as well but just ignore it now and start the car as normal. I think every software update since I bought it in 23 has made more issues than it’s solved. To the point I’m thinking of selling just due to the infotainment issues I keep having. All the important stuff is great but it just winds me up not connecting to my phone etc.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3491 ![]() ![]() |
Mine always connects with no issues whether l sign in or not. Not entirely sure what extra features l get from signing in.
One thing to check, if it's randomly not working or not signing in properly, mine used to to do this and l eventually discovered that l had two accounts in my name. Probably from when l initially set it up. So it would often connect to the second account and then didn't work properly. lf yours has issues, go into "Accounts" and make sure there's only one for you. lf there's more than one, delete the extra ones. |
Thank you yes that seems to have worked. |
