![]() | Home > Puma (Tdci) > What mileage would put you off a Puma (if any) ? |
revd Member Since: 20 Apr 2024 Location: England Posts: 277 ![]() ![]() |
It is more the age now that puts me off a Puma, I was once told by an employee that Ford only ever engineer a product for the first owner, beyond that they feel it's not their responsibility
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
Without knowing the age it is hard to answer that question. I personally wouldn't buy a Puma which had done fewer than 10k miles per annum, since not using them seems to be more deleterious than using them. I would certainly not be put off a high mileage one provided that it appeared to have been well-maintained.
Condition is more important than mileage. Bear in mine that the youngest Puma is now nine years old and the oldest 18 years old, so anything under 100k is low mileage. Says the owner of a Puma with 285,000 miles on the clock! |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921 ![]() ![]() |
Surely that statement has to be true for 99.9% of all car makers the World over..... |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1048 ![]() ![]() ![]() |
I’d rather a high mileage one thats been used and maintained well than a low mileage one that’s been sat in a garage. The lower mileage one has more chance of causing you a headache from being sat around.
120k is relatively in my opinion. All the big ticket items should have almost been replaced by that point and ready for another 100k. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1005 ![]() ![]() |
Mine had 185 on it when I purchased. Needed a few bits doing (vac pump,vcv, manifold clean etc) but ran really well.
Even if it was a 16 reg that is still not massive annual mileage. I would not be put off. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
120k is nothng really, a good service history and a clean straight motor at the right price your looking pretty good. check the usual obviously eg corrosion on chassis and bulkhead, oil leaks etc. 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
