![]() | Home > Puma (Tdci) > 2013 90 fuel tank vent |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 255 ![]() ![]() ![]() |
This thread has images of the Fuel Fill and Breathers on a 90
https://www.defender2.net/forum/topic25866.html Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Thanks Craig
What I need to know is the J shaped breather pipe visible when the tank is in situ? What people keep referring to as the breather pipe is actually the fuel return pipe. The small J shaped pipe with the one way valve is the breather pipe. I’m sure that on the TD5’s the J shaped breather pipe was located in the rear near side wheel arch and was visible. On my 2.2 Puma I can’t see is anywhere? Jim |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
https://www.lrworkshop.com/
Try having a look at the above link under Diagrams. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 54 ![]() ![]() ![]() |
Here is how mine has been installed.
![]() Click image to enlarge ![]() Click image to enlarge 2012 90SW - 2.2TDCI |
Thanks Trevor
![]() Jim |
