Home > Off Topic > 2009 Mini - failed MOT
Caterham
One for those that know their oils. Mr. Green
took my daughter Mini for an MOT and the short story is it failed on Emmissions (didn't fail first time round on emmissions).
Lamda - fail. I'm lead to believe this could have been a result of the exhaust leaking at joint after I removed / refitted.
Anyhow after having another go at jointing the exhaust along with exhuast paste. I've also put aload of Catoclean in the fuel and replaced the spark plugs. While at it I noticed the was little / no oil in the engine so chucked a few litres of some basic oil in until I do a proper oil change with filter etc.
anyhow now the the hydro carbons have gone from 10 to 210 - 200 being the limit. so now a fail on the hydrocarbons. Crying or Very sad
any thoughts - I'm wondering if the Catoclean was doing its stuff and cleaning all the hyrdrocarbons out the exhaust at the time of testing?
are there any oils out there I should be using that would minimise the hydrocarbon result as the tester suggested the piston rings have gone and hence the problem? Confused
Post #1069922 17th Jun 2025 8:16pm
BrickBox
Have you taken the car for a good run to get it right up to temp? 2008 2.4 110 Utility Station Wagon XS.
Post #1069927 17th Jun 2025 8:57pm
Caterham
I did do a 20 min fairly quick drive before hand but then it was sat for 20mins before it went for the test Sad
Post #1069931 17th Jun 2025 9:24pm
Siwynne
Try a new air filter. More air = better burn = less unburned hydrocarbons. Plugs torqued properly. Spark sits in the injector paths if it the right way round and can be shrouded by the electrode if 180 out. Small things to try but might get it below 200
Post #1070007 19th Jun 2025 6:55am
lightning
lt's common for the valve guides to fail on these older Minis.
The engine then burns oil, which is why there was none left in the sump. lt may be that refilling it with oil has increased emissions as it gets into the cylinders.
Post #1070068 20th Jun 2025 5:17pm
Dinnu
Could be that basic oil is not holding the viscosity well. I would go for a higher viscosity oil… do not let the engine idle too much, as that creates more vacuum sucking oil in, especially before the test. If the test center is close by, better as you have a warm engine but cooler oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1070093 21st Jun 2025 7:29am
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Pistons rings gone would mean blue clouds of smoke of revving..??
I would use correct Oil
Fresh Filters
Unleaded extra with a heavy dose of additive.
Good 40 minute run up the M42. Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #1070097 21st Jun 2025 9:48am
