Home > Off Topic > Metal Prep before Painting. Cast Iron Victorian Bench Legs
Grenadier
Hello all, or at least all of those interested in the subject.
We have four Victorian bench legs/arms made from cast iron, which we would like to paint. They have been stripped to bare metal. Obvious route is to slap some Hammerite on them and be done with it.
But on the other hand is the option to get a pro finish.
My question is over whether or not we need to pre-treat the metal (metallisation I think it's called), before we paint it?
The local shop has recommended metallisation and then doing an epoxy undercoat and poly final coat. Total price is 400€. Just the painting (epoxy + Poly) is 160€. Buying the Hammerite is 100€. So the painting makes sense, when factoring in the arsing about, but the metal treatment first?
The benches will be kept in the open air but under cover. One will be exposed to sun 365, one not at all - so we can swap them around.
Any metal types (not Iron Maiden fans) out there who can advise? Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1069499 11th Jun 2025 1:38pm
fogbank
Double
Post #1069502 11th Jun 2025 1:43pm
fogbank
Hammer- Censored is horrible stuff and only works with more of it, we had cast iron gates some idiot had painted with Hammerite, always flaked and looked awful
Post #1069503 11th Jun 2025 1:43pm
gilarion
Why not send them away to be galvanised, then etch prime and spray (with a rattle can) with Hammerite satin, in lots of colours. That way, they will last for years and years. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #1069504 11th Jun 2025 1:44pm
Grenadier
That sort of thing is so hard to do/find/organise where I live in France. Easy peasy back in the UK, but not so much here. Locally, what I described in the post is all that's available. Hence seeing value in the painting, but wondering about the metallisation. Thumbs Up Monsieur Le Grenadier
Post #1069506 11th Jun 2025 1:48pm
Grenadier
That's why I'd pay for the paint, but wondering about the extra stuff. Normally i'd just do it, but each leg has already cost 50€ to strip, and that doesn't even factor in the treatment of the teak. What's more this is part of an extended garden project that cost us 10s of thousands over the first qtr of this year and I am quickly running out of beer money. 240€ is 30 beers. Monsieur Le Grenadier
Post #1069507 11th Jun 2025 1:50pm
You could use cold galvanizing spray, then etch primer then top coat.
But cold galv isn’t any near as good as hot dip.
If you use a clear top coat that will add UV stabilisation, but equally you don’t want too many layers or it’ll chip.
Personally I’d go acid etch, then a satin base, then a clear.
You could just use satin asa top, but it’s life span will be reduced as there won’t be as much of a UV barrier, and likely grey after a while also. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069511 11th Jun 2025 2:04pm
Cast iron has a surface finish which promotes good adhesion. I'd simply prime and paint.
Post #1069513 11th Jun 2025 2:14pm
Ianh
Check out corroless as the primer and paint. Used on oil rigs so will last, I use on chassis.
I think Corroless S primer with Corroless RF16 topcoat would work, you just need to double check it’s ok for cast iron.
Comes in tins or spray cans. https://www.thomas-graham.co.uk/paint/corr...s-topcoats
Post #1069520 11th Jun 2025 3:35pm
Dinnu
Most of the steel parts nowadays I like to electroplate with zinc diy. Costs almost nothing. Its very easy and gives exceptionally good corrosion resistance especially after painting. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1069525 11th Jun 2025 4:33pm
1NRO
My current method for such tasks goes something like the following. As much prep as you can muster to derust, wire wheels on grinder and drill with rough sand paper handy. Blasting is worthwhile though don’t let them prime the item, thats just a good excuse to do a substandard job of the blasting. Two coats of a proper rust converter such as Bilt Hamber hydrate-80. Then a good coat of Jotun conseal, ideally sprayed on. it’s very easy to work with, well within the scope of a DIYer. A 2k product would be superior, there’s a number of good ones in the Jotun range but a bit more tricky to work with and obviously more toxic. The Conseal finish is satin so may not suit your ambition. A cheap compressor and spray gun will have you up and running.
Post #1069557 12th Jun 2025 7:40am
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
Epoxy (as we no longer live in the 1970s) and then a 2k single stage top coat.
Epoxy isn't generally an isocyanate, so you can spray without expensive air fed breathing kit. Or just brush on.
I use lechler for work, but there are others.
A modern epoxy is way better than hammerite or your 1970s etch primers.
Don't let anyone talking you into powdercoat either.
Post #1069586 12th Jun 2025 6:04pm
Powder coat is a pain in the backside for sure, best avoided. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069589 12th Jun 2025 6:19pm
