![]() | Home > In Car Electronics > Problem Electric Window Passenger Side |
ForceyBoy Member Since: 09 Jun 2025 Location: York Posts: 2 ![]() ![]() ![]() |
Hi All,
New to the site and the world of TD5's, but learning! I have a problem that I hope you can help with. The passenger's electric window is stuck open, now I have done the following: - Checked motor - all good - Checked wiring from post to door - all good - Checked switch - all good I can see that power is going into the relay, so I think that is the issue - though unsure of what replacement one to buy. If anyone could advise that would be great. Also is there anything else I should check besides this? Thank you for your help in advance and looking forward to getting involved in the forums! ![]() |
Thanks Landy Andy.
![]() Also can i check that this is the correct relay for the windows: https://www.amazon.co.uk/dp/B01JBRIGLM/ref...w&th=1 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6043 ![]() ![]() |
The window relay controls the power to the window circuit. So if one of your windows is working, or you have power to the switches you don’t have a relay problem.
