Home > Technical > 2007 Defender 90 Headlamp level setting help
RMA
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Looking for some help/ advice.
A friend of mine has a LHD Defender 90, (2007) and has bought a pair of aftermarket LED headlamps. The beams are coming up way too high. (even with the headlamp adjust moved to 3 from 0). Any ideas?
My only observation is that, compared to my 110 his rear ride height looks pretty low, versus the front. Which will obviously impact the headlights, I'm just not familiar enough with 90's to know how normal that is?
Post #1069189 6th Jun 2025 10:14am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Are the new LED lights of good quality and approved for road use? I am asking as I just removed my LED light that came with the truck, since no amount of adjustment would stop oncoming traffic to flash at me. A quick look through one of those instruments used to check the beam level revealed that their beam was all over the place. They could not be adjusted to be legal.
To adjust the height I use the screws at 3 & 9 o’clock. I’ve also tried with the 6 o’clock screw but can’t recommend it since that could have contributed to the failure of the levelling motor. If those are not enough I would check that the house sit properly in the bezel.
Post #1069195 6th Jun 2025 1:05pm
landy andy
The headlight is held in at three points.
3 o’clock
9 o’clock
And the adjuster on 6 o’clock.
If you can’t get enough adjustment on the base screw (6 o’clock) adjust the other two (3 and 6 o’clock) out. Which is the same, physically, as adjusting base (6 o’clock) in.
Hope that makes sense
Post #1069207 6th Jun 2025 6:28pm
Ianh
Just to elaborate, the standard adjuster screws have a captive washer under the screw head that remains in situ when the screw is turned . The headlight Bezel (mounting ring) lugs sit between the screw head and that washer.
Therefore if the screw is rotated clockwise the headlight moves in, if rotated anti-clockwise the headlight moves out. Hence following what Andy has said should ensure the headlights are adjusted correctly if they are CE compliant RHD lights and light Bezel is fitted correctly.
Post #1069209 6th Jun 2025 7:05pm
RMA
thanks all, in answer to the question "are they good quality LED's", they're at the better end of the spectrum but definitely not mega expensive.
Adjusting the 3 and 6 o'clock screws out, combined with the 6 o'clock screw inwards has made a huge difference, so thanks for all the advice.
the only issue I have now is that when I go to adjust the headlamp leveller (to compensate for having a heavy load) I'm hearing a noise as the motor kicks in, but it isn't having any effect...I wonder if I've overtightened the 6 o'clock screw. I'll have a play with that over the next day or 2.
Thanks again!
Post #1069281 8th Jun 2025 10:16am
landy andy
You need to have left enough room on the 6 o’clock adjust screw for it to adjust its self via the motor.
So you may need to bring 3 and 9 further out to compensate.
I was surprised how different my settings were when I fitted a new levelling motor the other month.
Post #1069282 8th Jun 2025 10:22am
RMA
thanks Andy, that was where my thinking was going too. Appreciate the quick and helpful feedback.
Post #1069283 8th Jun 2025 10:29am
