![]() | Home > General & Technical (L663) > Enabling 'Towing Pack' Features |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 274 ![]() ![]() |
Call Hunters Prestige and chat to them as a starting point
Others can do it too MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung 1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years 😂 1949 80" - still in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
Landy240 Member Since: 22 Jul 2024 Location: Merseyside Posts: 36 ![]() ![]() |
Ahh the tow bar issue.
Dealers will not help. They will install a towbar but at a far greater cost than factory fit. They will not activate software. If you have a dealer fit towbar you will pay a lot more than factory fit, but can then activate whatever you want aftermarket at a reasonable cost. If you fit an aftermarket towbar it is much cheaper but you have to make sure they fit the correct LR spec module - otherwise, although you can activate the software features, they will not interact with the towbar. It is an absolute mess. JLR are resolutely unhelpful. |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 184 ![]() ![]() |
My towbar was ordered on the configurator, six months later it arrived at the dealer without it. When I asked, they said they are not fitted at the factory, dealer fit only.
That's interesting. I was under the impression that ordering a towbar prebuild was so much cheaper than post build dealer fit because they don't have to dissemble the car to install it as it is done on the production line. |
Oneblack Member Since: 14 Oct 2024 Location: Here Posts: 39 ![]() ![]() |
I have changed my mind at the last minute and added the tow bar package though the dealer to be a part of my original factory build, mainly for the resale value (and to use the tow bar as a parking protector).
The dealer can surely add the tow bar after the delivery, but it will cost more and the can not ( will not ) activate the additional software features… |
