![]() | Home > Puma (Tdci) > Blowers |
kkma1560 Member Since: 10 Jan 2025 Location: East Sussex Posts: 3 ![]() ![]() ![]() |
Dealing with 2012 TDCI defender with air con.
I have managed to cause an issue with my blowers where by I am only able to select front window and cabin/front window. If I try to move to face/feet in cabin, or just face, the control knob is blocked. This seems to have happened when I was removing the dash to fix the wiper motor/spindles. The cable is connected and is intact. The lever on the side of the black blower box in front of gear stick appears to be limited now, and only has limited movement When I replaced the ducts behind the dash would I have caused an obstruction somewhere that would cause this? I took dash off again to look, but could not find anything, and am at a loss. Thanks. |
