Home > General & Technical (L663) > Mystery foam blocks
lightning
Mystery foam blocks
Taking out the rear floor on my D250 Commercial to check the MHEV system l came across two of these foam blocks, one was sat in the rear of the compartment just loose and the other was above the RHS suspension turret.
Neither piece was secure or seem to have any purpose. But there must be some reason why they are there.
Has anyone had the rear floor out of a 90 Commercial and do you know where these are supposed to go?
Post #1068623 28th May 2025 4:23pm
aajr
United States
I have the same foam blocks in my V8 Defender. They do not seem to do much other than perhaps keep cables in place or reduce noise, but I have no idea what they really do. They are held in place only by the pressure that is on the foam as it is pressed into the cavity.
On a separate subject, by chance have you take off that tray that the commercial unites have? Do you any pictures of the tray and of the underside skeleton to which it is mounted? Curious how that works as I was at one time thinking of converting my V8 to that set up to increase storage under the rear cover.
Post #1068643 28th May 2025 7:28pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
It appears to be some sort of sound insulator:
LR046744 Insulator With 5 Seat Configuration <11180B 1 CPLA C2159-EB
No idea where it fits though?
Have you tried scanning the QR code?
Jim
Post #1068665 29th May 2025 4:32am
lightning
"I have the same foam blocks in my V8 Defender"
Where were they located?
Post #1068810 30th May 2025 10:18pm
Philm
They are fitted under the side panels.
Probably to stop the squeaks.
Post #1068812 31st May 2025 7:56am
