Home > Maintenance & Modifications > Quick ratio p38 steering box
S1lverdale
Afternoon all,
I have had a 90 built for me… it USES A p38 steering box because the engine is a 5.0 mustang engine. The wheels are 20” and I have wide arches and use spacers to fill the arches…….
The car has no rattles, feels TIght and Goes very well (thank you Icon for building it). However the steering is vague and I want to crisp it up. I have a smaller steering wheel and new bushes etc. it seems to me that the box needs To be quicker….
Thoughts on who can supply a new quick ratio box please. Gratefully received
Post #1068487 26th May 2025 5:19pm
Chicken Drumstick
It's a live axle 4x4 designed to be used off road. The axle is distanced from the chassis by 8 rubber bushes...
I don't think you'll really sharpen the steering up. It is just the wrong kind of vehicle from a fundamental design point of view.
Haven't personally heard of a quicker ratio p38 steering box, the regular one is what Land Rover's own classic works use.
Quicker ratio would also mean heavier.
Post #1068502 26th May 2025 9:36pm
rustandoil
Post #1068503 26th May 2025 10:23pm
Zed
Back in the day Bowler used to sell a quick ratio steering box and it was very good. Unfortunately I have no idea who supplied them but they are out there. WARNING.
Post #1068540 27th May 2025 6:15pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
It was Adwest and not certified for road use.
Post #1068551 27th May 2025 9:23pm
HardCharger
Recently bought an OEM ADWEST 4 bolt LHD steering from LR Parts. It was sourced from China Shocked
Hopefully still good as what I'm replacing it with. No Better Friend, No Worse Enemy
Post #1068570 28th May 2025 9:07am
I'm really not sure I want to know that! Sad
Post #1068586 28th May 2025 10:57am
Linds Hanson
Overfinch originally commissioned the Adwest quick ratio box for RRC conversions it was something Land Rover also looked at when developing a more road biased RRC but never introduced it. It was never recommended for 90 wheelbase due to their sudden induced oversteer in the wrong hands. I fitted many over the years and found they sharpened up the steering considerably with obviously slightly heavier low speed steering. The P38 box is already slightly quicker ratio than the Adwest but I don't think anyone ever produced a quicker version, another Overfinch mod was to redrill the swivel housing location for the draglink ball joint closer to the housing. This again reduces steering travel but would require a engineering taper machining operation.
Post #1068590 28th May 2025 11:26am
S1lverdale
Thanks Guys for all of your assistance. It appears that, if the suspension is new and the steering damper (both from Alive Tuning), the p38 box is new/reconditioned/ the wheels and spacers are new and the bushes are new and I have a smaller steering wheel that I am Just going to have to live with vague steering generally.
I would have thought given the power and therefore speed that Twisted or one of the other companies providing high power defenders would have concentrated on providing precise steering….
Any thoughts or ideas would be gratefully received.
Post #1068688 29th May 2025 1:01pm
Linds Hanson
What tyre's are you running and what Panhard rod bushes??? Have you got uprated steering tubes/bars?
Post #1068690 29th May 2025 1:19pm
S1lverdale
Running 275x60x20 all terrain sport tyres by Renegade….
No idea about panhead bushes but I expect they are new….
Post #1068746 30th May 2025 4:23am
Mo Murphy
You have recirculating ball steering. It will never be as precise as rack and pinion steering on modern cars.
50 Shades of Pennine Grey
Post #1068751 30th May 2025 9:06am
Bluest
I have not tried it, but do intend to, my feeling is that HD steering bars would offer some improvement in steering precision. The stock ones can easily be flexed by hand which is not conducive to precise handling. Wouldn't speed up the ratio though. 2007 110 TDCi Station Wagon XS
Post #1068754 30th May 2025 9:15am
MercianRover
It's a tricky thing to improve given that they are beam axles with fixed caster and scrub geometry, more so given the warranty implications of modifying type-approved parts. Have you considered D2 axles? The front has significantly improved scrub geometry resulting from using open knuckles, not sure what they did with the caster.
You having spacers is going to make the steering more sensitive to feedback from clipping objects like cat's eyes and other surface deviations. I found a change as seemingly minimal as swapping 7" steel modular rims for HD tubeless made a big improvement in this aspect.
Post #1069875 17th Jun 2025 8:41am
MercianRover wrote:
... The front has significantly improved scrub geometry resulting from using open knuckles, not sure what they did with the caster. ...
Can you explain how the open or closed nature of the knuckle affects the geometry?
I can understand that the Disco2 geometry may be different (although I am not sure in what way and by how much) but since the geometry is just that - a particular set of angles and offsets - the open or closed nature of the knuckles is surely irrelevant?
An open knuckle is cheaper to manufacture and less prone to leakage which probably explains the popularity of the type. On the other hand it is a lot more complex to replace the swivels on a Disco2 than a Defender.
Post #1069878 17th Jun 2025 9:04am
