![]() | Home > Technical > Simple Door Check Fitment not so simple :) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
The bracket you have on the bulkhead is for a rear door.
What seems like you need are the bulkhead brackets from a defender. Series 3 doors had a slider in the door, part of the door frame. In Defenders, the slider is on the bulkhead, a bolt on, not part of the bulkhead. Google search will surely give you part numbers. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
