Home > Modifications & Maintenance (L663) > ECO mode
lightning
ECO mode
l don't suppose anyone has worked out a way to modify the software so the Defender defaults to ECO mode on startup, rather than COMFORT.
Post #1068301 22nd May 2025 8:04pm
DrRob
Nope but it’s awful in that mode 🤣 MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1068382 24th May 2025 8:06pm
lightning
For driving in town, between customers houses l find it the smoothest and it also saves fuel. On longer runs the default "COMFORT" setting is better as you suggest.
Post #1068383 24th May 2025 8:59pm
F-Typical
Why didn't you consider a Prius? Smile
Post #1068446 25th May 2025 10:49pm
lightning
l did consider a VW lD Buzz but it wouldn't tow the caravan
Post #1068459 26th May 2025 9:32am
Manuto
Canada
Re: ECO mode
you can by editing the CCF (using GAP tool or other).
what you are looking for is
MultiCAN-562 "ECOProgMode
Available for selection with timeout"
change it to "ECOProgMode
Available for selection without timeout"
Your car will restart with that mode if you had used it last prior turning the ignition off.
Post #1068923 2nd Jun 2025 7:44am
lightning
l will give that a try, thank you.
Post #1068928 2nd Jun 2025 8:43am
TexasRover
I am rather suspicious of these driving modes. It's quite simple for the manufacturer to tweak the throttle and gearbox responses so that ECO mode basically means 'light on the throttle' and early shifting rather than some sophisticated fuel map.
Was driving a rental car the other day and in ECO mode it was more like the throttle cable (which it does not have of course) was slack and only catching with the pedal fully on the floor. I could get the same fuel economy with just gentle driving.
It's basically a placebo effect.
Post #1068944 2nd Jun 2025 2:11pm
Cheshire110
Re: ECO mode
Ah I'll give this a try too! In the V8, eco mode is much nicer around town - the standard throttle response is quite racey Cheers, David
Post #1068964 2nd Jun 2025 5:33pm
lightning
Well, it worked on my 2022 90. Thank you "Cheshire110" for the information.
"the standard throttle response is quite racey" Yes it can be even on my D250 when you're just driving round town you don't need it.
Post #1068968 2nd Jun 2025 6:05pm
Mandodefender
United States
How does it affect the gas mileage?
Post #1069057 3rd Jun 2025 11:48pm
lightning
There's not much difference maybe 2mpg, l use ECO more because the response is smoother and better for city driving.
As it doesn't surge forward on acceleration so much when you touch the gas pedal l guess it uses a bit less fuel.
Post #1069066 4th Jun 2025 8:01am
VulcanCommando
United States
Re: ECO mode
I tried this but it still resets to auto, even after selecting eco mode prior to shutting off the car. Has anyone gotten this to work?
Post #1071658 18th Jul 2025 5:06am
DefenderMidlands
Have you rebooted Pivi a few times and locked the car up overnight. Sometimes these things take a while to work MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1071660 18th Jul 2025 6:13am
Manuto
Canada
Re: ECO mode
you may need the following change as well to work:
MultiCAN-566 MHLastUserMode = Enabled
Most people use that one to remember disabling the start/stop setting but might be required for the driving mode too
Post #1071663 18th Jul 2025 7:40am
