Home > Maintenance & Modifications > Boost alloys with terra firma spacers - conflict?
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
Internet seems undecided -
Do the flange nuts conflict with the alloy when using terrafirma 30mm spacers?
Some seem to say yes, others no.
For those who don't understand the question -
The alloy has recesses for the drive flange fasteners. Because the spacer rotates the wheel, relative to the flange, the recesses are no longer in the correct places.
However, there is 30mm greater overall clearance.
I suspect the make of drive flange and the bolts with which it's held on by are key in this, which is probably why the Internet is inconclusive.
I have terrafirma drive flanges and Allen cap bolts currently, so I'd be most interested to hear of anyone with the same configuration and their own results.
I do not want to start die grinding the alloy wheel...
Thank you.
Post #1068130 20th May 2025 2:58pm
landy andy
The standard bolts that attach the drive flange, or drive shaft will stop the spacers sitting properly. Fitting Allen cap bolts as you have cures this problem.
The wheel has no issues fitting onto the spacer.
Hope I’ve understood your question fully.
Post #1068132 20th May 2025 3:24pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
This thread from Land Rover Anorak
https://www.defender2.net/forum/post906625.html#906625
and this one from donmacn (Donald)
https://www.defender2.net/forum/topic58538-105.html
Show the issue with standard bolts and Boost wheels Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1068139 20th May 2025 4:05pm
julian
nice - thanks to both of you
Post #1068143 20th May 2025 5:27pm
