![]() | Home > General & Technical (L663) > D250 Engine Oil Volume / DPF Burn |
| Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 325
No smell in the Cabin during regen.
And my last oil change was 8L with new oil filter. |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3526
Mine takes 8.5 litres when drained using the sump plug and also replaced the oil filter.
l don't really smell anything during a regeneration, maybe a little outside the vehicle. Regeneration generally occurs between 200-300km depending on how it's been driven. |
| DazzlerAU Member Since: 21 Jan 2024 Location: Sydney Posts: 6
Does anyone know where I can find an online copy of the diesel manual with the correct ingenium engine? I purchased a copy a few years ago but it has the TDV6 for the engine section. I want to know how to diagnose the DPF process. Every DPF regen now I get a lot of smoke under the hood so there must be a leak but I can't determine which line unless I can trigger a regen manually.
After flushing with penrite engine flush, redraining, and refilling to high level, I can confirm that 8 litres is the correct amount for the MY 21 D250 when draining from the sump plug. Why does the manual state 9.8l? Still perplexed why I get smoke in the engine bay during a DPF regen and wondering if overfilling triggered it. |
My 2022 D250 takes 8.8 litres to the "full" mark on the dipstick when using the sump plug, 8.5 litres when sucking the oil out.
