Home > Maintenance & Modifications > Adding external battery points to easily charge the battery
Page 2 of 2 <12
jst
I run a 240 extension lead in through bottom front pass door, earlier puma without the later door seals there, 240v charger plugged into that. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1067828 15th May 2025 6:47pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I have the CTEK installed inside, connected to the battery using the above mentioned CTEK indicator plugs. Mains is fed in through a Defa plug and Socket.
This is sufficient for the intended amperage. The terminals in your inital post may be needed for jump starting and the 50A Andersons are also good for charging a Lithium battery at higher currents.
Post #1068021 18th May 2025 2:17pm
Vitesse
I tow a Penman trailer and use the Nato socket. This has a 12volt supply as part of the wiring. So this is very useful to use with a dedicated plug connected to a CTEK. Works well for me but appreciate is a large job on its own.
 2015 90 XS Santorini Black
Post #1068122 20th May 2025 1:05pm
Ianh
Using the tow socket s a very elegant solution. The only downside is it leaves the CTEK and the 240v mains supply in the elements and vulnerable to theft if used on a drive etc , i.e not in a locked garage.
Regarding being in the elements. Sure you can buy IP rated boxes to put plugs and CTEK in, place under vehicle etc, but it does add more cost and completely.
Post #1068126 20th May 2025 2:17pm
Trev
Scotland 2008 Defender 110 Puma 2.4 USW Zermatt Silver
I fitted one of these into the passenger side seat box and just close the door on the wires when the charger is connected. Work fine without causing any damage to the door seals.
https://www.amazon.co.uk/Anderson-Connecto...B0D5HRV65X
Post #1068864 31st May 2025 11:21pm
M94PUMA
I wanted one externally so could connect a Ctek charger whilst the vehicle is locked & alarmed and maintain a trickle charge etc.
Fitted on the front of the battery box, tuck up high enough not to be ripped off by anything. Out of sight as it’s hidden by the side sills.
Although I’ve fitted it and it works perfectly, I’ve never actually needed to use it. But least I can charge it if I ever needed to Thumbs Up
My TD5 90 will sit for 6 weeks quite happily and not drop charge even with a tracker hardwired.
Post #1068881 1st Jun 2025 10:15am
WestCountryPete
I used the ctek to 13 pin adapter so I charge using the towing socket. Worked OK so far for me. As nobody else has mentioned it, I’m now wondering if there’s a reason I shouldn’t be Laughing
Post #1069100 4th Jun 2025 7:32pm
M94PUMA
Yeah they work fine, charged my l405 Range Rover the exact same way through the 13pin for years.
Post #1069101 4th Jun 2025 7:36pm
andy63
As long as the max charging current of the charger you use is compatible with the existing circut you are using it won't be a problem
Installing your own dedicated socket and wiring will allow for larger chargers and charging current if its required..
Post #1069103 4th Jun 2025 8:38pm
M94PUMA
Yes absolutely, best to check what your wiring is rated for.
If I remember rightly ctek quick connect cables are rated for 10amp, so their chargers will be putting out less than that.
Most 13pin trailer wiring is 20amp or 30amp max load I think?
Post #1069106 4th Jun 2025 9:23pm
LR Nuts
I too used the Anderson connector method.
can be used for charging and jumping. (not at the same time)
Post #1069124 5th Jun 2025 8:25am
Page 2 of 2 <12
