![]() | Home > Faults & Fixes (L663) > Problems with the heated steering wheel |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 103 ![]() ![]() |
I'm pretty sure some other people have had an issue like this, and their heater for the wheel had just worn out and failed. Do your heated seats work?
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3467 ![]() ![]() |
l've heard of a few heated steering wheels failing. ln fact there was one at my local LR specialist when l was there last week, that they were trying to diagnose.
They said steering wheel is £2,400. l hope this is not correct. Although it's not the end of the world if it doesn't heat up, never had a heated steering wheel on my old Defender (or any previous car l've owned) |
Hazelhunter Member Since: 18 Nov 2020 Location: Hohenlohe Posts: 24 ![]() ![]() |
yes, my heated seats work without any problems ... |
Oh dear, that would be really bad news. A professional can definitely get this done cheaper, I hope. Thank you for your message ! |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1140 ![]() ![]() |
I noticed my heated steering wheel seems to have started failing. It only heats the rear section of the wheel where your fingers are. The section facing the driver where your palms are is cold.
£2400! Hell that’s a lot! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
£2400 for a steering wheel is
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Tanndoktorn Member Since: 18 Jan 2020 Location: Oslo Posts: 17 ![]() ![]() |
Did you find out if this was a defect, or if it should be like this? I have recently noticed the same problem om my Defender 2021, and I'm quite sure it hasn't been like this before. My dealer says the models from 2020-2022 (or so) only heats the rear section of the wheel. Only 2023/2024 and later heats both sides??? |
@Tanndoktorn
Your dealer's statement is 100% false! The entire steering wheel on my 2020 Defender was getting warm, front and back. My steering wheel heater has also been broken for a year, and now only the rear part gets warm. |
It would be nice if anyone with a '20, '21-model can tell me that both sides on their steering wheel gets warm. If I can give my dealer an example that goes against his saying, it would be easier to insist he should fix it on warranty (We have 5 years warranty here in Norway). He tells me he has tested several cars in his workshop, and only models from '23 and newer heats both sides of the steering wheel.
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 184 ![]() ![]() |
My 2020 heated all around. ( still worked up to selling it after 4 years)
My 2024 heats all the way round |
The whole steering wheel circle gets warm on my car too. The point is that just the inner part, the part facing the dash/my finger tips gets warm, not the part in contact with my palms ..
Can anyone confirm this is how it is on their '20/'21-model too? |
Yes mine was warm both sides
Anyone still having a '20/'21-model who can check?
oddefanten Member Since: 20 May 2021 Location: Oslo Posts: 3 ![]() ![]() |
I got this problem today, warm on the backside cold on the front. Has always been warm on both sides. I have a P400e MY22 that was delivered nov -21 22MY 110 X-Dynamic HSE P400e Pangea Green, Towing Pack, Cold Climate Pack
Past: Discovery 4 MY2011 SDV6 3.0 HSE Santorini Black |
