Home > Puma (Tdci) > pulling left
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
pulling left
I have owned my 2011 2.4 since it was 2 years old, i don't use it as much as i used to as i'm more into the series 1. But after one mot 2 years ago it started pulling left, i need to hold the wheel at 1 o'clock and if i turn it back to 12 it steers to the left. Had a look underneath, nothings bent or any signs of damage but i'm really into leaf springs and series stuff and these bouncy coils with their panhard rods and radius arms have many more wear points.
I managed 85000 miles on my factory fit tyres so fitted new ones all round a month ago, still pulling.
I removed and greased front wheel bearings along with swivel and stub axle seals and still pulling
what to try next? tracking? The car spent most of its life in a 50 zone on the a127 going to work so its never been abused. 1953 80"
1987 mini city e
2011 90"
Post #1067568 12th May 2025 9:42pm
BrickBox
Tracking is always my starting point. 2008 2.4 110 Utility Station Wagon XS.
Post #1067572 12th May 2025 10:33pm
Ianh
Nearside front calliper binding ? As it heats up the disc will expand and bind increases. This will generate heat so be careful when checking after a drive.
At the mot they would have tested brakes, hopefully with a Decelerometer and not on a single roller !! In doing so the brake pistons may well have got a bit stuck on the caliper if the vehicle had not been driven on regular bsseis.
Above is just a pure guess but easy to check.
Post #1067575 12th May 2025 11:17pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
“Pulling left” means if you let go of the steering wheel, the vehicle steers to the left. You have to maintain constant pressure on the steering wheel to the right to keep it straight. It’s like driving with a very strong crosswind.
I think you mean that the steering wheel is not straight when going straight but it otherwise drives fine.
Which is your problem?
Post #1067578 13th May 2025 4:34am
Ianh
Good point JB. If that’s the case they could have adjusted the tracking but not kept the steering wheel centred when they did so. That would cause the steering wheel to not be centred when the steering is centred.
Post #1067599 13th May 2025 2:41pm
MR_JAMES
If i let go yes its pulling left. I only had time after work to take o/s wheel off today and something looks iffy with the axle, i will include a photo but it looks like shifted forward, the shock is at an angle and the bush at the bottom is not in properly? If thats not supposed to look like that could it be the radius arm bushes?
 1953 80"
1987 mini city e
2011 90"
Post #1067643 13th May 2025 10:31pm
jbcollier
The axle is located by the radius arms. Have a close look at their bushings for a start.
Post #1067691 14th May 2025 1:59pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
You can also check the trailing arm bushes in the rear.
I had an interesting ride home from the workshop at work when I had, in a hurry, replace one side of those and forgot to mount some critical parts. Whistle
Post #1067712 14th May 2025 5:23pm
rustandoil
We have checked the tyre pressures? 😉
Post #1067714 14th May 2025 5:56pm
That damper bush looks like it’s past its best, are the top ones visible or under the “top hat” turret if you have one?
What are the rear ones like?
Has there been any work done on the brakes recently?
If the steering was off, it would be off centre I’d have though not pull to one side.
If it pulls to one side I’d say more body weight shift due to bushes or brakes, worn bushes can make things feel all over the shop when distributed body weights shifts under steering or braking input. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067723 14th May 2025 8:14pm
lightning
lf the fault occurred after the MOT then something must have happened to it at that point.
lt's highly unlikely that the garage could have bent anything unless they took it for a drive and crashed it.
Tracking isn't usually adjusted at the MOT, but it's possible. It's straightforward to get it checked and adjusted if necessary.
Post #1067729 14th May 2025 9:17pm
MR_JAMES
Thank you all for your advice. Going to replace some bushes and see how it goes. 1953 80"
1987 mini city e
2011 90"
Post #1067930 16th May 2025 9:36pm
They very likely gave most of the bushes a good pry, steering bars, joints, A frame etc etc. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067972 17th May 2025 5:35pm
