Home > Puma (Tdci) > Fuel Cooler
Naycrx
Fuel Cooler
Just been under our defender and noticed a slight drip from the fuel cooler..... it's the coolent pipe (orange fluid) that pushes on I presume?
Question is will it need a new one ? I'm not sure if I remove it if I'm going to loose all the coolant, or can new connections be purchased
Best
Post #1067701 14th May 2025 4:08pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
If you clean the surrounding area and then unplug it, you will drain approximately 6 l of coolant. You can catch it in a clean container and reuse it if it is in good condition.
Before doing that I would try to figure out where from exactly it is leaking, once drained that’s a bit harder unless you can see something obvious.
Post #1067706 14th May 2025 4:58pm
Ianh
You will loose almost all of your coolant as that’s the recommended drain point for a coolant change.
Edit - Johan got there before me Very Happy
Post #1067707 14th May 2025 5:02pm
Naycrx
Hi.
Looks like it's weeping from the push connection. Pipe looks ok, seems to be pushed on ok , unless it's worn and needs to be a tighter fit
Post #1067708 14th May 2025 5:02pm
You can always take it off quickly and refit, but be quick and keep a clean container present ready to put it back in if you need to.
There is indeed and incoming / outgoing fuel pipe there, and the same for coolant, as it’s coloured as you say then it’s coolant, it might just need reseating.
My guess is someone has been at it, trying to pull it off before without unclipping it properly, possibly.
Personally as a drain point I prefer the thermostat drain hose, it might not quite be the lowest point but drains faster, when I later used the cooler I found nothing there to have worried about anyway.
OAT Coolant lasts well with a very long life, so luckily not a job to have to do often.
I have Motul Autocool (orange) in mine, meets LR specs. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067725 14th May 2025 8:21pm
Naycrx
Great thanks all for.the reply..... I'll give it a try tommorow after I have purchased some coolant
Post #1067846 15th May 2025 8:41pm
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Most of the push type connectors seal with an o-ring and these go flat over time.
If you take the connector off and remove the o-ring you should be able to match the size. Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #1067950 17th May 2025 10:41am
