![]() | Home > Technical > Front Door Help |
| BobGFish Member Since: 09 Jan 2025 Location: Zug Posts: 35
I have a 2014 Puma and the front doors have been screwed over.
I pulled them apart and the door lock button thingy and all the components are missing. Central locking still works. The door cards are held on with screws in random places. Was hoping to sort it out. Ideas why someone might have bodged this? Easy to get new parts or try a wreckers instead? I would guess parts 21-26 from the link at least. https://parts.jaguarlandroverclassic.com/p...and-rover/ Also when the door cards come off it has a thin foam layer over the inside of door which is glued on around the edges. Is this normal? I can't find a part number? I thought it may be a water shedder but his appears to be inside the panel inner? (anyone have a pic of inside front door?) Also on one side where the check strap is attached to the door the bracket is bent. See pic. Is this part replaceable or part of the door? Lastly I have the doors hit the A pillar. I have brought a "kit" to fix this. How to access this? Not a dash out job is it? The buffer is missing I think. Can someone post a pic of where it should go? Many Thanks Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
