Home > Puma (Tdci) > RHD Right side Front light and right rear side light problem
jackie44chan
Australia 2012 Defender 110 Puma 2.2 SW Barolo Black
Hi everyone, I’ve run into a strange issue 🙃
On my Defender, the right-hand side sidelight isn’t working unless the ignition is on (the left side works fine). When I turn the ignition on, the right sidelight—including the front one—comes on only when I press the brake.
Could this be a fuse issue, or does it sound like a wiring problem? (I haven’t done all the wiring myself.)
Post #1067289 8th May 2025 1:54pm
Mo Murphy
Sounds like an earthing problem
50 Shades of Pennine Grey
Post #1067305 8th May 2025 5:32pm
Check the earth for the rear harness, which is located on the offside of the transfer box. It sounds as though the brake light is earthing through the tail-light filament.
Post #1067308 8th May 2025 6:06pm
