Home > Faults & Fixes (L663) > Front parking sensor fail
Page 2 of 2 <12
Lockley
Keep us posted. I shall be booking mine in soon. It seems unlikely that all front sensors will have failed simultaneously, and without any faults showing! Let's wait and see. L663 D300 SE MY22.
Post #1028299 16th Mar 2024 9:12pm
Nitroneil
Looks like I will booking mine in to get them to look at sensor problem, all but the rear not working. But now got security updates to do as well so guess its worth a call. 90S D250 fuji and loving it.
Post #1029451 27th Mar 2024 8:44am
Lockley
See my post above. I’ve now booked mine in at the dealer to be looked at under warranty and have the security updates done at the same time.
In the meantime, my gap tool has thrown up an error code related to the front left parking sensor. The dealer explained if one sensor goes out the whole front (or rear) parking aid is deactivated. L663 D300 SE MY22.
Post #1029458 27th Mar 2024 8:54am
XplusYplusZ
Mine's started doing this too. Solid red lines around front and sides of pivi parking display. Allows me to get mighty close to objects in front. Rears work ok.
Any updates on the resolutions?
Post #1041026 26th Jul 2024 10:42am
Nitroneil
Mines in garage just now, seems to be a front failed sensor after all, although rear parking sensors still working as they should. 90S D250 fuji and loving it.
Post #1041027 26th Jul 2024 11:02am
Gareth
Mine had this last January. It was fixed by the dealer just outside of warranty.
Unfortunately it’s just happened again. Not sure they will do a second fix under goodwill. Especially when I ask for goodwill on the very expensive matrix headlight that has failed drl and halo! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1047193 29th Sep 2024 2:21pm
XplusYplusZ
My front left sensor was faulty and was just fixed under warranty. I wonder if it might have been why my stupid car kept jamming on the emergency brakes without anything in front of me...
Post #1047385 1st Oct 2024 1:25pm
Moo
Ukraine
I've often wondered whether we should use the Consumer Rights Act more with LR.....
https://www.which.co.uk/consumer-rights/re...JYx8n5KiSl
With the number of fails being reported and repair kits available from third parties, it would suggest that this is a quality issue. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1047391 1st Oct 2024 4:53pm
Mukafuka
has an official fix been found for this? Im pretty sure my sensors are all fine (placing my finger on the sensor, I can feel all of them 'tapping" and the sensors will spontaneously start working from time to time.
Post #1055962 31st Dec 2024 3:18am
Freddy801
United States
Parking Sensor faults? Try this....
Hi All,
Just wanted to throw this into the discussion. I recently did some off roading so I aired down the tyres to 20 psi and had some fun in the sand. When I aired back up to road pressures, I discovered my parking sensors no longer worked - I had a full red box around the cameras. I assumed it would clear itself after they had dried out and I washed the car.
The fault didn't clear so I took it to my dealer. It turns out the fault was due to the over-pressure of my tyres (the compressor gauge was faulty so I accidentally aired them up to 57 psi!) Once I reduced the pressure, the fault cleared completely and I had parking sensors again. Believe it or not, this is actually documented in the i-Guide too!
Just a suggestion and I hope you get the problem fixed.
Post #1057275 13th Jan 2025 5:56pm
Mukafuka
Any updates?
Post #1067238 7th May 2025 5:22pm
Page 2 of 2 <12
