Home > Puma (Tdci) > Engine Warning Light Issues on 2015 Defender 2.2 Td4 - P2263
Page 2 of 2 <12
hunting_defender
Austria 2015 Defender 110 Other SW Orkney Grey
Thank you for the instruciotns, digging into it this afternoon with a friend of mine - he is an electrical engineer, he helps me out!
Post #1067149 6th May 2025 1:00pm
andy63
Hope you get a result and don't forget to post your findings.. will be interested in how it goes..👍
Post #1067151 6th May 2025 1:26pm
hunting_defender
Good evening,
Sure took notes Thumbs Up
I did measure out the pin‘s:
- Actuator (C2519) to ECU (C0411)
- Voltage of the 5 pin‘s
- Actuator to ECU: all Pin‘s beeped, the green (GND VNTP) one was a little bit reluctant
- Voltage:
White (C2519-1) to Blue (C2519-2) 1,783 V
Green (C2519-3) to Violet (C2519-4) 0 V
Orange (C2519-5) to GND of the car 4,980 V
When the engine was running and we hit the accelerator Orange (C2519-5) to GND of the car went up to 4,995 V and White (C2519-1) to Blue (C2519-2) to 1,886 V.
Not quite sure why the green one was a bit reluctant, maybe because I couldn’t properly reach the pin.
Does the voltage look normal? Anywhere to check?
Best Regards
Post #1067173 6th May 2025 8:15pm
andy63
If I was checking the voltages I would be going from the pins on the actuator to ground...not between the pins as you seem to be doing.. ie white to blue etc.. I'd be checking white to ground..
Here is what I'd expect..with engine running at tick over..and back probing them connector terminals..
Pin 5 white/orange...5v
Pin4 purple/brown...2 to3 v, it will vary if you get someone to press the accelerator..and the actuator arm moves..
Pin3 green... 0v.. or close to that..it's the ground..so minimal voltage drop ..
Pin2.. and pin 1 the blue and white motor drive wires.. the voltage on these will vary and may show up as a negative value , but the important bit is you see the actuator arm moving up and down as you get someone to operate the accelerator..
Was your continuity check done with the connectors disconnected from the two components.. I'd say not really necessary if your voltage readings and operation are correct. And if the components, ie actuator and ecu are not disconnected you could be checking anything, not just the wire connecting the two..
That's my thoughts..
Have you tried your new actuator yet?
Post #1067199 7th May 2025 7:54am
hunting_defender
I also measured each pin to ground - similar values. The change in voltage was done that way.
I will do it again later today.
How do you measure and check if the arm is moving at the same time?
New actuator should arrive today, latest tomorrow! then I can check proper function!
Post #1067201 7th May 2025 8:28am
andy63
It's a visual check.. the actuator rod that connects to the turbo vanes actuation ring should move.. it is a rotary drive out of the back of the actuator and connected to the rod that moves the vanes.. you should see it moving..
That's what I was saying from the start.. in the video you posted it didn't appear to be moving.. if it doesn't move there is no turbo boost control..
If electrically all seems well but there is no actuator movement as you operated the accelerator then its likely damaged the drive in the actuator..
When you replace it have a look inside...you will likely be able to see the issue..
Post #1067202 7th May 2025 8:48am
hunting_defender
That is fully understood Thumbs Up
https://share.icloud.com/photos/007KN2825P9z1p8OLAmwvEWnA
I took a video of the valve itself - seems fine to me!
Let‘s hope the new actuator will do the trick!
Post #1067220 7th May 2025 12:18pm
andy63
Any joy with your actuator.. it's good to get the results of any issues 👍🤔
Post #1067589 13th May 2025 10:14am
Vitesse
Actuator
Just thought I would add here that I have had recent P2263 code issues. The end result was a faulty actuator. The turbo vanes were working perfectly once I could check them with the actuator removed . I bought one off eBay via the link earlier in this thread. So far so good and has also stopped an air induction noise similar to a boy racer popping the wastegate. Power delivery is also improved. [/code] 2015 90 XS Santorini Black
Post #1069887 17th Jun 2025 1:40pm
Vitesse
Just for interest , I took the original actuator apart. No obvious fault but there was some small particles Inside. A couple of pics
Post #1070494 28th Jun 2025 2:24pm
andy63
Nice to get some feedback..
I can't make out clearly whether there is damage to the position feedback sensor dial teeth.. the motor worm drive looks OK..
If the actuator was stuck and the motor was still trying to drive it that's where I'd expect to see something give ..
Post #1070495 28th Jun 2025 2:37pm
Vitesse
Thanks. I am going to conduct some more detailed examination when I get some time
👍😀 2015 90 XS Santorini Black
Post #1070502 28th Jun 2025 4:52pm
andy63
Ive never had one apart.. the motor drive does appear from your picture to have what is possibly a clutch or spring loaded relief on the drive , but I suppose it depends on how long it was trying to drive stuck vanes for..
Post #1070514 28th Jun 2025 8:42pm
Page 2 of 2 <12
