Home > Puma (Tdci) > Propshaft EMERGENCY!!!
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Hey guys
So getting this noise while driving (see video https://youtube.com/shorts/GXUs8K3T8d0?feature=share)
Only happens when applying power, generally from third gear onwards. No shaking in the steering, no feedback in the pedal, just the noise. If I lift, it stops. If I accelerate to gear up it stops just before the next gear then starts again as the gear engages.
Mech is sure it's the UJ on the prop shaft. I got a pair of "defender" UJs and sadly they don't match. The thing is the shaft was already removed and the mech did NOT mark the position the shaft was connected in (which I'm seeing is always recommended).
My question is, is there a default configuration for the replacement of the shaft (axle/ratio)? Or any way to replace the shaft so that there are no issues or the driving isn't affected?
Also, what could go wrong?
I'm in Trinidad, so it takes a while to get parts down here from the UK. So I "have time" I just don't like my truck left anywhere too long. 110 SW 2.4
IZUMI BLUE
Post #1067026 4th May 2025 7:19pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
The orientation of the propshaft where it bolts to the transfer case and / or differential flange doesn't matter. However, if the propshaft itself is slid apart and separated into its two halves, then it is important that these are put back in the same orientation they were prior to disassembly otherwise they will be out-of-phase.
Post #1067079 5th May 2025 1:38pm
TriniDaddy
Ah!!! Got it. Thanks.
Actually expecting a total replacement of the front shaft anyways so that should work out. 110 SW 2.4
IZUMI BLUE
Post #1067100 5th May 2025 8:13pm
I don’t know if it’s helpful or not, but remember you can always run 2WD with diff locked if you need to.
Can be really helpful, if you need to keep going with a Prop out.
Just make sure if it’s the rear, you bolt the handbrake drum back on. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067101 5th May 2025 8:15pm
TriniDaddy
Well, that's a bit out of my scope atm. Hopefully I never have to use that option.
Great tip though.
I must say man. You really know these cars. I wish we were neighbours. 110 SW 2.4
IZUMI BLUE
Post #1067103 5th May 2025 8:19pm
We’re like a big family, help one another out, knowledge is shared and mutual respect garnered for every member.
Though these things are often shared, it’s useful to know, as nearly everyone has encountered such problems once, so knowledge to fixes and repairs are, really helpful to everyone.
Especially useful at a particular point which could be urgent you know. That kind of thing.
Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1067178 6th May 2025 9:57pm
TriniDaddy
Trust me. I really do appreciate it.
Just to update. I was gifted an entire driveshaft so just swapped out the front. Back on the road and right as rain. Will get the Ujs and put them in my old shaft and keep as spare.
Thanks for the advice. That transfer box tip was excellent. 110 SW 2.4
IZUMI BLUE
Post #1067242 7th May 2025 6:23pm
Ianh
When you say driveshaft, do you mean front propshaft ?
Post #1067243 7th May 2025 7:22pm
TexasRover
Americans confusingly call propshafts driveshafts. I know why create all this confusion!
Post #1067276 8th May 2025 12:51pm
Australians call the rear propshaft the "tailshaft". I don't know what they call the front propshaft.
Post #1067278 8th May 2025 12:55pm
Ianh
“Nations separated by a common language “ Very Happy
Post #1067280 8th May 2025 1:01pm
