Home > Td5 > TD5 ECU repairs
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
TD5 ECU repairs
During last winter I have spent some time with non working TD5 ECUs and as a result I made schematics of the ECU internals and I think, I understand how the hardware of ECU works. Here are some pictures and videos of ECU testing with crank signal simulator: https://www.rajce.idnes.cz/ok2mtm/album/td5-ecu-oprava-repair
I was able to repair quite fast 10 ECUs I had here as death on arrival for long time. Problems were different, often broken passive component, but never problem with the two big capacitors.
To simulate the crank sensor signal I use basic Arduino board with short and simple code. For first test runs I was using spare set of old injectors, but it is quite noisy, so I made some solenoids with screws used as cores and to make the running ECU audible a visible.
Non repairable are ECUs totally burnt (small burnt through hole is still possible to repair) or drowned for long time. Bot of these results in too big much damaged parts.
With schematics faults like TOP SWITCH are possible to diagnose and repair. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1027263 8th Mar 2024 11:43am
MadTom
And some more pictures:
Signal from crank sensor simulator.
Burnt ECU - this is not repairable.
Home made test bench.
During test the ECU is powered from old battery, because it has no connection to ground and makes some measurements simpler. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1027264 8th Mar 2024 11:50am
Martin
Site Admin
Very impressive Bow down  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027265 8th Mar 2024 11:53am
Prisk81
Italy
Hi, do you have problem some times with rpm 0, so not start? In diagnosis I have 0 rpm in cranking but with oscilloscope on ecu pin signal is good...
Post #1060392 12th Feb 2025 6:05pm
TexasRover
Are they robust generally? I have a 15p Td5 and manage to get my hands on a free 10p ECU which I keep for emergency spare, i understand this would get you home.. (I have a nanocom)
Probably should be looking for the correct ECU, but look a bit pricy?
Post #1060393 12th Feb 2025 6:28pm
Prisk81
Italy
I try to repair my ecu before search another one.
Post #1060412 12th Feb 2025 8:41pm
MadTom
For "emergency" run of TD5 engine, you can use any engine ECU, just "solve" immobilizer - pair it with car of "remove" from ECU. In one car (Defender TD5 or Dicsovery 2 TD5) you can pair more than one engine ECU, so after this basic "preparation" it is just plug and play. No need for any diagnostics use.
All TD5 ECUs use the same hardware for controlling injectors. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1060522 14th Feb 2025 8:59am
jonny
If you are keeping one for emergency use (eg. overlanding), there's probably a few more steps you should take - copy the injector settings over etc.
But 'cloning' one ECU to another is fairly well documented so if you were going to the lengths of having a spare ECU you may as well clone it totally when you disable the immobiliser..
Post #1060533 14th Feb 2025 11:09am
Prisk81
Italy
Thank you. I have found the resistor/ fuse connected with injectors gnd blown,it measure 1,6 kohm now I must known value of it and after see for other component that can have damage
Post #1060538 14th Feb 2025 12:36pm
Marco5579500
France 2003 Defender 130 2.5 TD HCPU Indus Silver
ECU burnt
Hello MADTOM,
Could you help me please ? I figured out that my ECU had burned. Two components seem to be affected: a transistor and a small component I don't recognize.
I saw your work and i wonder if you could help me to identify the component references. So that i can buy them and try to repair my ECU !
Or if you have a schema with the name/references of thoses components.
Here are the pictures of the problem.
Thanks a lot !!
Marc
Post #1067003 4th May 2025 2:11pm
Prisk81
Italy
Photo of component?
Post #1067005 4th May 2025 2:56pm
Marco5579500
Post #1067007 4th May 2025 3:10pm
MadTom
This burn part of ECU is DC step-up, it makes 85V voltage used to controll injectors. You can replace these 2 componnents, but I think, there will be more burnt/broken, than just these.
There are corroded screws connecting the big capacitor - was the ECU drowned? "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1067208 7th May 2025 10:13am
Martin
Site Admin
Hi MadTom
Any pointers on where to focus attention on a Td5 ECU (very late, 2006 NNN500020) which shows no sign of life?
No glow/no MIL/no fuel pump/no response to Nanocom, but have good 5V supply from both the regulators inside.
Just didn't switch on one morning!
Any advice appreciated Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1073618 18th Aug 2025 7:50pm
Martin
Site Admin
Bump  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1074531 1st Sep 2025 9:47pm
