![]() | Home > Technical > Timing TDI 110, 1985 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
If the crank is getting ‘stuck’, could be piston hitting a valve. Check your camshaft / valve timing. I hope you did not try to start. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
cecilkift Member Since: 19 Jul 2024 Location: California Posts: 8 ![]() ![]() |
Got it all lined up after I took the top engine cover off. Timing is all setup now,
Let's hope it starts when I close it all up |
