![]() | Home > Puma (Tdci) > Spare ECU for trip |
bcmeijer Member Since: 05 Nov 2008 Location: The Hague Posts: 11 ![]() ![]() |
That's exactly the base of my question. Every other part is replaceable by a local mechanic or myself. Except the ECU. For a TD5 it's possible to program a spare and put it away in case you need it. Maybe this is also possible for a puma. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
If you really want another ECU as back up? Then get another one and replace the ECU in the vehicle with it, then get it programmed in situ so everything works as it should. The original ECU can then be used as the spare as it is already programmed for your Puma, though IIRC you will still need diagnostic gear to change the ECU serial numbers within the IC and still have to do DDS learn for the 10AS/ immobilizer.
Brian. |
The trip was nov-12 till feb 13 and we drove 20700 km in 10 weeks.
Besides a fuse and a intercooler hose which blew of one time, i snapped a bold on my turbo (top one). Put a clamp on it and drove back to Buenos Aires. It was a great trip. |
NT5224 Member Since: 10 Jul 2012 Location: Robin Falls Posts: 50 ![]() ![]() ![]() |
Congratulations!
It would be good to hear more about that trip. Will you be posting anything here? Alan |
