Home > Technical > Ashcroft LT230 High Capacity Sump TDCI
Jimbob292
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Zambezi Silver
Ordered the above made a huge difference, well worth every penny. Cracking service as always, from ordering to delivery.
Just finished a 300 mile trip, noise & heat wasn't a problem, with the added volume of oil, and the ability to keep it cool. Fitted a Thermax strip, showed that the casing didn't reach 82c, before i was touching, just a tad under 100c.
Exhaust pipe hasn't caused any adverse issues either.
Post #1066624 29th Apr 2025 6:32pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
I've got one on the kitchen table here (!) - ordered the seal for it this afternoon.
Will fit it soon.
Post #1066656 29th Apr 2025 10:09pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hi
Does this come with a gasket or did you use silicone sealant?
Post #1066685 30th Apr 2025 11:35am
julian
I dont think youre asking me, but mine came from another supplier - they mailed me after saying they had forgotten the gasket, and offered to send one, but i just added it to a subsequent order.
So, i will use both the stock gasket, and also the hylomar (or whatever its called) stuff.
Post #1066688 30th Apr 2025 12:13pm
It's been years since LT230 transfer boxes used any gaskets, they are assembled with RTV such as Hylosil.
Post #1066696 30th Apr 2025 1:18pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I've got one on my bench just waiting to be fitted before this year's adventures.
Post #1066707 30th Apr 2025 2:06pm
andy63
Re: Ashcroft LT230 High Capacity Sump TDCI
Is it just the camera angle..that exhaust coupling looks far to close to the casing, given you could expect some exhaust and transmission movement..?
Post #1066709 30th Apr 2025 2:14pm
Bluest
I sold mine without fitting it because of how close the exhaust was to the high cap sump. I was concerned about heat and even whether the 2 could come into contact on corrugated tracks. I'd be interested in feedback from.anyone who has done say a Morocco trip with one fitted. 2007 110 TDCi Station Wagon XS
Post #1066730 30th Apr 2025 8:40pm
andy63
I thought about fitting the larger sump to the transfare box, but after fitting a 3' demand exhaust that sort of ruled that idea out as I just don't think there would be the room..
I have done Morocco with the standard transfare box.. and have checked the casing temperatures after a bit of a run..
by no means a detailed investigation but don't recall seeing anything alarming..
Engine sump in the 80's and transfare box in the 50 to 60's centigrade..
Those stick on strips would be the better way to record the max temperatures in use is suspect..
Post #1066733 30th Apr 2025 9:02pm
Oldowner
I had an Ashcroft Puma modified sump too but never fitted it as still too close to the exhaust for my liking.
Many years ago I regularly drove a 300tdi from Cornwall to a Scotland in the middle of the summer, the gearbox tunnel used to be roasting hot. I imported the high capacity sump from Roverdrive who were the original designers and it made a difference to the temperature when fitted so they are worth fitting.
Post #1066747 1st May 2025 6:33am
BrickBox
I have read that removing the centre silencer of the exhaust makes quite a difference in cabin heat also. As that’s a bit heat holding part. 2008 2.4 110 Utility Station Wagon XS.
Post #1066749 1st May 2025 6:41am
Jimbob292
kmac wrote:
Hi
No it doesn't, i used Hylosil, as per the other post.
Will take differing angle picture showing the exhaust, its not a stock exhaust, its a S/S free flow.
Post #1066751 1st May 2025 8:39am
True, and that also includes having one less big item under there to get hit by anything. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1066879 2nd May 2025 6:35pm
