![]() | Home > Maintenance & Modifications > Wiper issues, they don’t clear the whole screen |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
What do you mean by the wiper ‘wheels’? Do you mean the wheelboxes?
The two types of wheelbox (to 2001 and 2002 onwards) have different tooth counts on the gears, and so you need the corresponding gear in the motor to match otherwise it could affect the sweep angle. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
If you have changed from the early wheel boxes to the later wheelboxes then the ratios are different and the gear needs changing in the wiper motor gearbox to get full sweep.
Joeytf Member Since: 20 Sep 2024 Location: Somerset Posts: 42 ![]() ![]() |
Legends! Ok I’ll get onto that. I’ll try and find a part number. Mine must be the early type and I’ve defo fitted the later type wheel boxes
