![]() | Home > In Car Electronics (L663) > Pivi Pro 4.3.0 Update and info |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3317 ![]() ![]() |
Maybe the update didn't come through on the vehicle before handover. It seems to arrive at different times for owners.
essentian Member Since: 02 Apr 2025 Location: East Mids Posts: 45 ![]() ![]() |
I believe the LR techs are able to manually flash the latest SW.
Oneblack Member Since: 14 Oct 2024 Location: Here Posts: 35 ![]() ![]() |
got mine delivered roughly a month ago, and am not able to check which version I have (just says "vehicle software up to date", without the version number).....
so can't even tell if I have the 4.3..... |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 135 ![]() ![]() |
That is normal. It will say that until the software is updated for the first time, then it will tell you which version you're on. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar) ๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 279 ![]() ![]() |
Land rover assist (by pushing spanner button on roof panel) can push the software updates to your car but will only do it if it is to fix a problem you are having. MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Might give that a go, seeing that Iโm hoping itโll fix/help an issue Iโm having with the gearboxโฆ
Mine had a gearbox issue when l first got it. Some changes were not smooth and there was a delay in engagement at times. Land Rover Assist came out and updated the gearbox software. lt's been fine since then.
the LR Assist solution is probably only going to work in the UK....
just don't see that happening in eg. Austria or Germany... ![]() |
Theyโre out tomorrow to look at mine, fingers crossed! Do you recall how long it took them to re-flash the gearbox SW? |
LR assist came out this morning. Plugged in & couldnโt see any pending updates, despite being on 4.2.1. Didnโt have a view on why neither 4.3/4.3.1 were showing
I think the Pivi pro updates can only be sent over the air by Land Rover, Not done by plugging computer into car onsite. MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Gotcha, do you know if the dealer has the ability to request a push? If so Iโll get it booked in.
Iโm not sure. Land Rover customer care can if they deem it will fix an issue for you
โOur phoneline is open Monday - Friday 08:00 - 15:00. Call us on 0370 500 0500โ MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar Last edited by DefenderMidlands on 27th Apr 2025 8:23pm. Edited 1 time in total |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
Updates get pushed to cars in batches, depending on model and market etc. so thereโs no need to request it specially.
It will do it by itself in time. |
