Home > Puma (Tdci) > Replace oïl sump 2.2 by better part
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi there,
My oïl sump does not look that great. No salt and no corrosion on my chassis, axles + boxes, engine, the oïl sump looks quite rusty...
As far as I can remember it was replaced for warranty issues about 10 years ago. I think it has been glued.
Is there a better part to replace that rusty oil sump on a 2.2 tdci engine ?
Post #1065968 21st Apr 2025 9:13am
Vitesse
Hi there. I had my 2.2 Puma from new in 2015. The sump pan was rusted in 2 years while the rest of the underneath was perfect. The warranty did not cover this so I was told. Either way I didnt want another one fitted by a dealer to simply rust again. So I purchased a new sump from the dealer and had it professionally re painted and fitted it myself. That was 7.5 years ago and it’s still in perfect order. There was no gasket. The special sealer adhesive came with the new sump. Removing the old sump was tricky due to the adhesive. But if you take care it’s not too bad. 2015 90 XS Santorini Black
Post #1065969 21st Apr 2025 9:20am
Bluest
I bought a.replacment sump after my original rusted badly, I was.concerned it was going to start leaking. I bought Britpart or Bearmach cheap replacement, but I prepped, primed it and painted it with Buzzweld CIO. It still perfect 8 years later. 2007 110 TDCi Station Wagon XS
Post #1065975 21st Apr 2025 10:32am
Julie
Lots of thanks. Yes, I may buy a new sump made from that cheap sort of steel and 'give it a shot of DIY paint. This is a good option.
1...2 layers of zinc based coating
1...2 layers of PU paint
to spray from the outside. I'just a bit scared if it then rusted on the edge where a visual inspection cannot be performed
I was looking for an upgraded part. Better alloy. No options of that kind ?
Post #1065983 21st Apr 2025 11:16am
