![]() | Home > Technical > R380 holes - please restore my sanity! |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239
Drain plugs to let stuff out when stuff has gotten in. Replace them.
| Big Juss Member Since: 03 Mar 2025 Location: Sunny South Coast Posts: 16
So you're saying that there should be plugs in them all the time?
Correct
Thanks for your help! Sorry for the repeated questions - will this have harmed my gearbox? It's tricky going into 2nd when cold - separate issue?
| htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548
I leave red bottom one out. The higher blue circled one i leave plug in, Its to allow setting engine to TDC.
Perfect, I'll order a plug in that case. You've set my mind at rest! Thanks
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2787
Drain plug (lower one) should only be fitted when wading or for heavy mud work. Leave it out the rest of the time so you can spot any leaks.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Leave both plugs in permanently and remove lower one on a service to check.
There is an oblong hole at front of bell housing that remains open all the time check this is clear. Poking a cable tie up works well for this. That is how it was designed to be used. No plugs in there won’t have caused any gearbox issues, and being tight going into gears when isn’t a rare problem. Get an oil change done on the box, and see what it’s like. But these boxes just like you to take your time to change gear. Click image to enlarge |
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 538 |
On earlier Land Rovers - it specifically stated in the handbook to leave the drain plugs out and to only install them if wading or extreme off-road conditions.
This was to allow any oil that had seeped out into the bell housing to drain out and not contaminate the clutch plate. The plugs were also in early 90’s and 110’s stored from new in the toolkit roll. |
Yes. Earlier ones told to leave out, later ones leave in. Don’t think the early boxes has the extra little drain like R380
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
My Series 2 has a neat little bracket to store the plug when not in use 😎
| All times are GMT |
