![]() | Home > Puma (Tdci) > Output shaft failure, Forum Survey |
just a thought.....( ![]() would the easiest option simply to be seal the extension casing in place, add a drain and fill plug....and bingo. lubrication sorted - no more wear ? (and obviously half fil with oil). |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 588 ![]() ![]() ![]() |
Thank you for being updated. Normally, I'd ask for a refund. But I had the spline installed at LAND SERVICE in the north of Paris. They have the most complete stock of Defender spares here in France. They're one of the top 3 when it comes to Defender workshops. They also confirm your concerns that a rigid spline must not be installed. The red one has been fine for 10 000 kms and température changes from 45 to -8 °C - including a Sahara trip in winter. If it starts loosing oïl, I'll contact you. |
About 8 years ago, I read about somebody who installed a grease nippel on the spline and cut off the housing. I think it was in this forum. This would have been some smart Ashcroft solution, wouldn't it, Dave ? Once a year in autumn it may easily be greased with the other points... Last edited by Julie on 21st Apr 2025 8:28pm. Edited 1 time in total |
About 8 years ago, I read about somebody who installed a grease nippel on the spline and cut off the housing. I think it was in this forum. This would have been some smart Ashcroft solution, wouldn't it, Dave ? Once a year in autumn it may easily be greased with the other points... |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3594 ![]() ![]() ![]() |
The problem with pumping it with grease is that it can easily build up pressure behind the shaft, and push the shaft out of the cup.
The aftermarket ones seem to be doing a better job than the original JLR design, and each one has its own merits, pros and cons. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
2 vehicles of the same date may have different coupling expectancy because they're not exposed to the same conditions : température changes, load changes, humidity etc Tge first one is a daily commuter, parked on the street and the second one is a camping car parked in a dry heated room only running on long distance trips in summer. Everyone would confirm that the second one much longer expectancies - not just with respect to that damn spline, but almost any part (exhaust, engine, cooling, EGR, DPF ...) |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2450 ![]() ![]() |
A lot of the damage is due to rust being ground between the mating splines.Therfore I think humidity has a role to play here as well.
Vehicles left several days between use are, if moisture is present, more likely to devlope a small amount of surface rust on the splines. When next used the surface rust is ground to the orange dust that is captured in the cup. This in turn grinds down the splines. Therefore vehicles in high humidity / wet environments that are not garaged and have several days between use will be likely to suffer more from wear due to rust grinding. Obviously having oil on the splines as per the ashcroft solution prevents this. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1296 ![]() ![]() ![]() |
You would think there are lubrication solutions out there that provides very long term lubrication with a single (installation) application. I have a small tube of Sachs special clutch spline lubricant I use for clutch installations.
I don't have a Puma, but at some point had a RRC automatic (torque flight) where the output shaft into the LT230 was dry and worn away, which was a common and well documented issue those days and solved by adding a hole in the imput shaft allowing gear oil to lubricate the splines completely solving the issue Little surprising they found themselves with a very similar challenge 30 years later, but now we have superior lubrication solutions |
Spare parts and warranty replacements came with a small grease package. Obviously, JLR engineers found that hint, too
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17909 ![]() ![]() ![]() |
This would not be particularly easy as the extension housing is not sealed, there are cut-outs in the area near the gear selector mechanism. I know of at least one main dealer which, in the early days of this becoming a problem (i.e., prior to 2010) was fitting diametrically-opposed grease nipples and drilling the housing to allow a grease-gun to be used. I don't know how effective this would be long term but suspect that most owners now don't know what a grease-gun is. In most cases thorough lubrication with a suitable grease followed by careful assembly (I am sure that some joints are not properly assembled hence the partial separation we've often seen) will make failure so rare as not to be an issue. My own joint is the original and has now done 280k miles, it was greased with molybdenum disulphide grease when I last changed the clutch (about 140k miles ago). I do however believe that a lot is still down to luck and on some vehicle the aggregated tolerances are such as to mean that the shaft is not straight and will consequently wear. The best answer to this is to keep the joint wet-lubricated and for this the Ashcroft coupling is the best solution. |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 124 ![]() ![]() ![]() |
We used to have a highly regarded Land Rover mechanic in the south of Sweden, sadly he passed away last year, but just before I asked him for advice on my intermediate shaft. What he did then was to start the engine, put the transfer box in neutral and the main box in gear, releasing the clutch. He then listened to any noise coming from the transmission and quickly concluded that everything was fine with this shaft. According to him, a worn shaft would start to rattle and make a noise. Can this be confirmed as at least being some indication that something bad is about to happen?
Possibly, provided that the vehicle was on a lift and you could listen specifically to the adaptor shaft housing.
The problem I would anticipate is that the clutch on a TDCi Defender is very prone to rattling and will drown out the noise of the adaptor shaft rattling. You'd have to make sure exactly where the rattle was coming from. It is actually not a difficult job to take the transfer box off and inspect the joint, and I think that this is really to only reliable way to check the shaft. It also of course gives the opportunity to lubricate it and make sure that it is properly assembled. |
I was thinking - fill the drain point with a dab of weld. gasket sealant on the faces to seal it and a fill point / breather and a drain point and you're good to go ![]() BUT. why bother is good grease / correct assembly will get you 100k miles? |
My clutch does not rattle (confirmed by good mechanic). When my spline got worse 'n worse, I did not hear any rattle . What element rattles in a rotten spline ? I can imagine some "crunchin"-with all the rust particles milling down that spline. Just like a rotten gearbox ... However, many people see rust as an indicator coming out of the hole in the spline housing before the spline looses its grip. |
