Home > Maintenance & Modifications > SP 4x4 Truwsteer Upgraded Steering Box Review
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Morning folks, this is an FYI post for anyone that is considering fitting the above upgraded steering box from SP 4x4. I bought the kit that includes the drop arm a month or two back and got round to fitting it on Friday. It's a lot lighter and less bulky than the original part and was pretty easy to fit to the chassis. Lots of posts on forums suggest the steel hydraulic hose does not line up correctly...no kidding, it was about an inch and a half out. But some careful and gentle bending puts it in the right place eventually. One issue I came up against was the splined input shaft. There is a groove machined into the shaft to allow the pinch bolts to locate. The groove is not quite as deep as the standard box which meant the pinch bolt did not line up with the threaded part of the clamp so it cross threads. I had to file a flat into the shaft to get the bolt to pass through correctly.
https://www.sp-4x4.com/QAF500110_POWER_STE...defkit.htm
Other than that it was pretty straight forward - the question is then is it as good as they say it is? I would say yes - it is a higher ratio so feels more direct, no slop (might be because my old one had deteriorated significantly). The steering is also markedly lighter which is really nice, with a light clutch courtesy of LOF and light steering courtesy of SP 4x4 my Defender is almost unrecognisable as a Defender! It's quite pricey compared to a reman unit but my experience of those has been mixed, they get either loose, leaky or both pretty quickly.
So, initial reactions are good, let's hope it lasts!
Post #1065468 14th Apr 2025 2:00pm
BrickBox
Price looks good and if I’m reading right, you don’t need to send your old steering box! 2008 2.4 110 Utility Station Wagon XS.
Post #1065482 14th Apr 2025 4:43pm
Penfold_6290
Correct, there is no core charge for this part so there's nothing to send back.
Post #1065483 14th Apr 2025 5:01pm
Oldowner
I fitted one for someone a while back that they supplied. As well as the steel pipe issue and having to open up the groove for the bole in the input shaft, I also had to swap out the bolts highlighted in the photo. The outer lower bolt fouled the chassis coils spring bracket / gusset, I had to replace the bolt with a button head Allen bolt without a spring washer, and even then it was sat against the chassis bracket
Post #1065535 15th Apr 2025 3:10am
TexasRover
If you dont have ABS consider fitting the double diaphragm brake booster from LOF and your brakes will be light too!
Post #1065538 15th Apr 2025 6:09am
Penfold_6290
That's a bit of a worry, I didn't notice any issues like that with this one but I'm going to have a good look to make sure when I get 5 mins.
Post #1065591 15th Apr 2025 3:04pm
hank
These look great! Damn you, another thing on the shopping list... > 110 XS Double Cab
Post #1065592 15th Apr 2025 3:07pm
Oldowner
Personally I wouldn’t bother if yours isn’t leaking, I couldn’t tell any difference from a good genuine box. It was only fitted as the original box had had the preload messed with causing broken up bearings
Post #1065616 15th Apr 2025 9:51pm
hank
My original was leaking and loose so I fitted a "good" used one which is now leaking and loose beyond adjustment so it was on the list anyway. This seems a better solution > 110 XS Double Cab
Post #1065632 16th Apr 2025 8:53am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Interesting.
I wonder why the LHD version is not compatible with the Puma Defender though, does anyone know the reason?
https://www.sp-4x4.com/QAF500110_POWER_STE...defkit.htm “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1065635 16th Apr 2025 9:59am
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
^^^^ I have the same question - but no answer Laughing
And also noted that the LHD version still has the external pipe visible, whereas the RHD version has it built internally into the casting.
/Mat
Post #1065645 16th Apr 2025 11:13am
Penfold_6290
The LHD looks like a totally different design to the RHD one...look at the pics side-by-side and all castings look entirely different.
Post #1065775 18th Apr 2025 2:40pm
HardCharger
I asked them if they had a LHD Puma steering box, no bueno. They said they don't have them. So only the RHD guys are fortunate enough to use them. Sad. Big Cry
And I needed a new one too so it would've been perfect as they cost much better than a new ADWEST one from LR Parts. No Better Friend, No Worse Enemy
Post #1066031 22nd Apr 2025 8:12am
