![]() | Home > My New Defender (L663) > Coolant Loss and "shunty" gearbox. |
| Yorkshire90 Member Since: 22 Sep 2011 Location: Yorkshire Posts: 205
Sorry, just realised this is absolutely in the wrong place 😑
Click image to enlarge New 6cyl 3.0 Diesel. Only covered 2.5k. That seems like a lot of coolant lost on my father's 90. He's been to the dealership. Booked in Tuesday for a check. Won't provide him with a top up. He's too concerned about buying an incorrect coolant as I believe it's SiOAT and nothing seems to come up compatible locally. Dealer suggested topping up with water. No thanks. "Yes... They all use coolant...it's normal" No it isn't. Gearbox also has a clunk, a shove you feel in your seat when engaging drive and setting off. Also rolls back on hills about 30cm. Are they meant to hold position? Again, "they all do that" from customer service. A brand new 60k motor. Seems worrying to me. Thoughts and advice? Even if it's directing to a safe coolant. I have some Comma G40 OAT (Pink)...not sure. [/url] SOLD "Big green" 2000 Td5 90 IRB Developments modified (2004-2011) SOLD Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-forever (most likely!) Daily drives: Mercedes E250cdi E Class estate, Modified Skoda Yeti, 05 Honda Jazz for those short runs! http://www.defender2.net/forum/topic11056.html |
| WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 182
The JLR Spec for coolant is: STJLR.651.5003
Try Opie Oils https://www.opieoils.co.uk/search.aspx?search=STJLR.651.5003 Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
Thanks for the feedback. We'll it's been topped up today at LR. Will keep a check on it. Diagnostics not throwing anything up with the gearbox. The rolling back issue is because the hill start feature wasn't activated
| jenzz Member Since: 14 Dec 2024 Location: Frankfurt Posts: 7
Yes, check out the "Faults and Fixes" Section, you're not alone. |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
the roll (forward and back) is a problem many of us have...it wasnt on my last 2 it is on this, worse on the courtesy car and i would say its dangerous
you can make it easier but its still a pain. Mike |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3528
My D250 coolant level seems to settle at the low mark in the reservoir when the engine is cold.
However when the engine is hot, it's at the "max" level. See below. So if l top it up to "max" when the engine is cold, it will eventually end up back at "low" (with an occasional smell of coolant from the front of the vehicle) Click image to enlarge |
| Snorki Member Since: 12 Feb 2024 Location: Wald Posts: 13
Had the same issue with my MJ24 90 SE. After a couple of 1000km in winter time the loss started. Then i took it back to the dealer who checked for pressure losts twice, Dec and Jan. No losses found. I added cooling again for 3 times, now it keeps the level at max as it should be. Also after 3000 km through Spain in summer at 37 degrees - no losses anymore. Maybe sometimes it is just a rest of air in the cooling pipes?
