Home > Puma (Tdci) > Random cut out
bear100
Random cut out
It started 5 years ago in the south of France, we had just left the campsite and stopped at a bakery for breakfast, Start the engine pulled off and then the engine cut out, Tried starting, but the engine would turn but not fire, Ignition off back on it started fine.
About six months later while driving the engine cut out for a split second, This has been happening more frequently lately. Roughly every five starts of the engine from cold it will fire for a second then cut out I restart the engine and it’s fine. Sometimes when idling the revs drop and come straight back. On occasions, I have to cycle ignition three times for it to fire.
Any ideas? I’ve fitted a genuine VCV last year but to me it more electrical. Possibly the multi plug in the dash? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1065380 13th Apr 2025 7:59am
VCV’s are fickle, and vary in lifespan, but if you do think it’s electrical then main power supply connections are worth checking, from ground points to main lives and battery clamps etc.
Usually these things get loose due to vibration over time, Relays loose in their sockets can be an issue, or slight build up of corrosion on the sockets / pins. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1065384 13th Apr 2025 9:35am
andy63
As above.. check the supply and ground to the power relays and ecu..
A waggle test of looms whilst running.and the same on the crankshaft sensor wiring..
Fault codes or pending codes worth checking , and possibly better still if if the tool is capable of the landrover specific codes , rather than just generic obd..
Post #1065406 13th Apr 2025 1:37pm
landy andy
Battery in remote fob???
Post #1065418 13th Apr 2025 4:40pm
bear100
Thanks chaps
I don’t thinks it’s vcv related tbh, when it’s not firing it’s like the immobiliser has kicked in?
I’ve changed the crank sensor last week during my head rebuild, will check the wiring.
I’ve got a Nanocom and I have no idea why’s I haven’t checked Shocked
Been so involved with the rebuild common sense has gone out the window! It slipped my mind I had it 2023 Defender L663 V8
Post #1065420 13th Apr 2025 4:46pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
If it cranks, then it is not the immobilizer.
Post #1065471 14th Apr 2025 2:52pm
