Home > Maintenance & Modifications > Britpart transfer box are they any good?
Fuzzynme
Hi I'm wondering if anyone has had any problems with the Britpart LT230 transfer box. I'm looking to replace mine. There seems to be quite alot of shiny new Remanufactured ones available but no reviews. Would be grateful for your feedback. Many thanks
Post #1064969 8th Apr 2025 7:52am
Have you taken a look @ Ashcroft Transmissions? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1065001 8th Apr 2025 3:22pm
excossack
Or winchester gears? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1065006 8th Apr 2025 3:54pm
Fuzzynme
Thanks for the replies, yes I've looked at Winchester gears and Ashcroft. Price wise these Britpart ones are a good price and you get to keep your old one to rebuild as a spare. I would be grateful if their's anyone on here who had bought one and what they think of them. Many thanks
Post #1065012 8th Apr 2025 4:25pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Britpart is an emotive subject in Land Rover circles.
A few years ago I serviced my daily drive, a 2005 L322 Range Rover using Britpart filters. Back then I didn't give it much thought but within weeks the Rangy started running rough.
I was advised that it was an injector problem, so as there were 100,000 mile on the clock I replaced all 6 injectors. It still ran rough.
I then was told that the fuel pump was knackered. So, once again, I bought a nice new fuel pump and fitted it. It still ran rough.
My daughters then fiancé was a Land Rover Master Tech down in Bristol. He popped up for a visit and to try to help me sort the rangy out. By this time I had spent well over £1000 chasing the cause of the rough running.
We opened the bonnet and the first this he said was "What's a Britpart fuel filter doing on this?" He then suggested either a Mann or genuine LR filter swap. A couple of hours later a Mann fuel filter was fitted. Turned the key and once again my Rangy was purring like a kitten..
Since then I've never bought anything Britpart apart from fastenings and trim items. Personally I wouldn't even consider fitting a Britpart transfer box. There's a reason they are so cheap...
Jim
Post #1065066 9th Apr 2025 5:08am
TexasRover
Britparts does make good parts, but it is a bit hit and miss. There are parts where Britpart is the only option and you just need to assess and take your chance. At least its not expensive typically.
When you have an option I normally take the middle ground (OEM) unless it is a critical items or something hard to change later in that case I might go LR original part.
Coming from a Series landrover I started to hate the gear noise, which the a good LT230 does not suffer from. I recently swapped out a noisy LT230 with a good used (unopened) one and it was an al-round success. You should look at that too. In fact a Britpart transfercase might just be that. It will not be new, but could be a 'tested' good used unit, cleaned up but never opened and overhauled.
If it turns out to bad/noisy you would have to go through the effort of removing and returning it.
Post #1065070 9th Apr 2025 7:34am
Fuzzynme
Well thank you both Jim and TexasRover, very much appreciate your time and feedback.
The main reason I'm drawn to the Britpart LT230 is Yes they're cheap but they are not asking for the old one as return. Having one to rebuild myself is appealing.
Lots to think about, keeping in mind your valuable feedback.
I'll keep looking around.
Post #1065077 9th Apr 2025 8:23am
Re: Britpart transfer box are they any good?
I've never heard of anyone having problems with one, but then again I have never heard of anyone fitting one either!
There is plenty of scope for Britpart to mess up an LT230 (and Britpart does seem to have a talent at producing some startlingly bad parts), but it is very unlikely that they built their own LT230s. I suspect that the the important question is from where does Britpart source these.
Post #1065088 9th Apr 2025 9:59am
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
I've got a knackered (bearings) lt230 on the garage floor that I need to rebuild for a project.
I would rebuild this, rather than buy a britpart branded box.
The difference for you is that you don't have a donor box on your floor.
The cost of acquiring a knackered donor box would probably be quite minimal.
If you get the britpart one, the rebuild your old one, are you then going to swap the rebuilt one back in? And then do what with the britpart one?
If you just buy a donor one, rebuild it, you can swap the known good one directly in.
I suspect (I don't know) that britpart is just distributing these. They won't be new castings etc. I think someone will be rebuilding them and then flogging them though britpart.
You can buy optimil parts with britpart part numbers now. The knee jerk reaction against anything with a DA part designation is foolish.
But is whoever is rebuilding these (if my suspicions are correct) using nice bearings etc. Who knows. Maybe you can find out somehow?
Again, I'm sure someone must have a dead lt230 that they would sell you if you ask about.
Post #1065092 9th Apr 2025 10:04am
Fuzzynme
Hi all, really appreciate the response. Alot to think about, I think I'll take the plunge give the Britpart LT230 a a go. I'll give a review once it's all over. Many thanks
Post #1065184 9th Apr 2025 11:50pm
Mo Murphy
Probably of Turkish origin and rebuild, distributed by Britpart. It'll probably last the years warranty.
Good luck with that, I'll stick with Ashcrofts.
50 Shades of Pennine Grey
Post #1065189 10th Apr 2025 5:38am
Jimbob292
United Kingdom 2012 Defender 110 Puma 2.2 DCPU Zambezi Silver
Hi,
i just wouldn't touch a blue box of death, bought a coil for my V8, i was in a bind, caused me rough running until i fitted a Bosch one, learnt my lesson the hard way.
I've always used Ashcroft's the service is impeccable, fitted a few air lockers & ATB's, auto rebuilds & LT230's all still running to this day. The lockers can really take a hammering, and then some.
If you've a question, the whole team are bang on the button with replies, non of this leave a message, or email with zero response like from other outfits.
Post #1065219 10th Apr 2025 11:35am
ashtrans
Site Sponsor
very kind of you to say so,
we work hard on staff training, website and ordering systems / processes to improve the customer experience in the office as well as in the workshop to constantly improve the process and product whilst making sure we learn from warranty issues when they arise, Dave
Post #1065252 10th Apr 2025 7:43pm
jst
I suggest they don't want your old unit as they know your going to need it. You could buy Bridport one, rebuild your old one with quality parts from say Ashcrofts, then fit that to replace they probably knackered Britpart one.
Or just fit an Ashcroft one in the first instance and not need yournold core unit.
I guess it depends if you like changing t boxes and want the option to rebuild your own? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1065270 11th Apr 2025 8:03am
Fuzzynme
Thanks everyone for your feedback very much appreciated. I'm learning alot very quickly. This is a great site. Hopefully won't be bothering you for a while. Just continue reading the threads and learning.
I've decided and ordered a Stage 2 Winchester Gears.
Post #1065279 11th Apr 2025 11:35am
