Home > Maintenance & Modifications > 110 TD5 wheel alignment tolerance
Epicurus1992
United Kingdom 2005 Defender 110 Td5 XS CSW Bonatti Grey
Hi all,
Having replaced the tie rod ends on a 110 TD5 (stock set up with no relevant mods), I took it to get the alignment checked for free at a garage with a fancy lazer machine. The results show Left Front Toe minus 0deg15', Right Front Toe minus 0deg 34'. So just less than half a degree out in total.
It drives fine, but is that enough to affect tyre wear over time?
(The rears, which I know are not adjustable, are Left minus 0deg27' and Right minus 0deg23', so my assumption is that the fronts are within the realms of reasonable tolerance)
Thanks!
Post #1064928 7th Apr 2025 4:48pm
Not worth worrying about.
The normal tool for Defender wheel alignment is a tape measure!
Post #1064929 7th Apr 2025 4:55pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
He's not joking. I align mine with a sort of extendable curtain pole and it drives great with no odd handling or tyre wear .
Post #1064959 7th Apr 2025 8:17pm
Epicurus1992
Thanks both- confirmed my thinking!
Post #1065044 8th Apr 2025 9:12pm
