Home > Maintenance & Modifications > Brake squeak
Sillyoldme
Brake squeak
Hello
I’m expecting the answer to be- it depends! But I’ll give it a go anyway
Had my 110 for a few years now. Came from a LR dealer with the Land Rover used approved scheme. Which I think in reality it meant they cleaned it really good before selling!
Anyway; a couple of years on and the pads needed replacing, as they were worn, there was also some squeaking noise at times
The squeak came back soon after that and was even worse
Then I was told the discs needed replacing as one or two are lipped and might be the cause
New discs and pads fitted two weeks ago
Two days later- the squeak is back!
Any (good) ideas what else to replace that might be the actual cause?
I don’t want to think it’s another defender thing as i see a lot of these care around and none squeak like mine! It’s embarrassing!
Post #1064881 6th Apr 2025 8:40pm
TexasRover
No I don't think it is a Defender thing, but my rear brakes started squealing recently after I overhauled the calipers. At the time I found the backing plate (soft-ish) plate at the back of the pads had come loose and I left it out. I understand these backing plates are there to stop squealing so I bought a new set of pads which I intend to fit soon.
What pads where fitted? I think some cheaper aftermarket might not have any real provision to stop the squealing. The Quality of the brake pads are definitely a factor.
Post #1064907 7th Apr 2025 1:26pm
It not clear exactly what you mean by squeaking - do you mean when the brakes are applied, or all the time the vehicle is in motion?
The only rear pads I have yet found for my 20076 110 that don't squeal when applied at some stage in their life are genuine LR pads. Even quality aftermarket seem to squeal. All pads also tend to rattle unless the anti-rattle springs are in extremely good condition and correctly fitted, there are non-standard anti-rattle springs which can also improve the rattle prevention.
Post #1064921 7th Apr 2025 4:05pm
landy andy
Agree with above. A previous Defender always had brake squeal. Only way I found to stop it was to fit Land Rover pads. And I tried many other brands.
Post #1064922 7th Apr 2025 4:06pm
I find the standard pads to actually be the best for longevity and reduced issues.
I did use EBC Green at one time, they were fine but found them to be a bit lacking cold, and when at temp get over heated instead. No noise related issues though.
So I use the standard type, last well, no issues, a lot of noise issues are down to poor installation or hardware in my opinion. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1064926 7th Apr 2025 4:16pm
Ianh
From my experience the Gen LR pads work well, last well and don’t squeal on my standard 2.2 110 CSW. Given they last so long it’s not an extravagance to use them. Wisely buying a few tanks of diesel will quickly cover the extra cost above the cheaper pads. Wink
Post #1064934 7th Apr 2025 5:36pm
Sillyoldme
Yes they squeal when brakes are applied. Worse in the rain.
I’ll give that a go. They’re not that much more expensive and probably cheaper than other aftermarket gear…and cheaper than new callipers which was the next thing they suggested I change!
Post #1064935 7th Apr 2025 6:04pm
Mo Murphy
Before biting the bullet on new pads try a light smear of coppaslip on the back of the pads where the caliper piston pushes it.
50 Shades of Pennine Grey
Post #1064941 7th Apr 2025 6:29pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I spent ages trying to sort out the dreaded 110 rear brake squeak.My 90 has never had this problem...
The reason the genuine pads don't squeak id they come with anti squeak shims,from my research I couldn't find anywhere that sold just the shims,so,I made a set myself from 0.3mm sheet steel.I already had 1 old one to copy for a template.
You have to make sure to fit them the right way round,effectivly so that the caliper piston pushes the pad so as the leading/front edge or the pad touches the brake disk first.I hope that makes sense?
Marc.
Post #1064945 7th Apr 2025 6:47pm
