Home > Maintenance & Modifications > Chassis cleaner - dry mud/sand ?
FD7
2006 Defender 90 V8 Petrol ST Auto Chawton White
Seem to have found myself underneath a new to me Defender today and noticed it was covered in a lot of dry sandy mud.
I have tried (as best I can) pressure washing / snow foaming and then some localised cleaners /degreasers alongside brushing, but it's taking an age. The only positive out of this is that areas I was able to clean have highlighted a very solid chassis!
The gearbox and transfer box area are covered by all of this too.
Has anybody got a good recommendation for a cleaner which is perhaps more powerful?
(ideally something that won't strip away any of the underbody chassis coating)>
Post #1064873 6th Apr 2025 6:31pm
BrickBox
You’ll have to use a hot power wash on something that dried on. 2008 2.4 110 Utility Station Wagon XS.
Post #1064875 6th Apr 2025 7:36pm
ickle
Mine was only just over a year old but was caked inside and out with Spanish red dust and mud - I left it on axle stands as high as possible, but angled down at the front, then set an oscillating garden sprinkler underneath on a timer - a couple of minutes per hour for 24 hours, this really softened the mud, then I used a Karcher on the outside and a drain snake inside.
After drying for several days I lathered it in various Dinitrols and MIL Spec cavity wax and 15 years later chassis is still superb
HTH Keith
Post #1064879 6th Apr 2025 8:30pm
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi
Do an internet search for your local truck wash. They will normally do a full chassis and underside clean for a reasonable price.
You are then left with a blank canvas that allows you to assess the condition of your chassis and running gear, make repairs if necessary but most importantly treat for rust and then apply one of the many 'protective' products to help keep corrosion at bay.
Jim
Post #1064889 7th Apr 2025 4:33am
Leave it to dampen, a lot of it is where it is dry, personally I keep pressure washers away far too much damage and water pushed in where it shouldn’t.
It does take a lot of time to do a top job.
Are you painting or rust proofing? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1064919 7th Apr 2025 4:03pm
FD7
Thanks for the tips.
The aim was to assess the rust proofing and top up if required. However it's mostly the inner rails and gearbox / transfer and lower engine that were dusty/dirty.
I'm quite satisfied in the condition of the chassis, it remains solid and black. Almost as if the dry mud has formed a protection layer.
It is more in this case for my vanity purposes for wanting the mechanical components a little cleaner.
I will dampen dampen dampen, perhaps use a TFR and localise steam clean the area. Given the better weather at the minute it seems doable, otherwise I will find a truck wash ....
Post #1065062 9th Apr 2025 4:22am
jim4244
My local truck wash (Northampton) charges £50 and there is not a speck of dirt left anywhere on the underside..
Jim
Post #1065063 9th Apr 2025 4:36am
